Best quick fix for rusted wheelwells? - Ford Truck Enthusiasts Forums
Paint & Bodywork SPONSORED BY:
Old 03-06-2005, 01:54 PM
michaelbarry's Avatar
michaelbarry michaelbarry is offline
michaelbarry is starting off with a positive reputation.
i have an 84 F-150..and it is rusted around the rear wheelwells...i'm not planning on keeping the truck for over 2 years...what would be the best and easiest quick fix for them?..i was thinking about cutting out the rust,putting some of that foil tape on the backside of the hole that would be there after cutting out the rust,then take some fiberglass and put over it,and then finish over that with some bondo type filler...does this seem like it would last around 2 years?...thanks in advance..
Old 03-06-2005, 03:57 PM
jesse1385 jesse1385 is offline
jesse1385 is starting off with a positive reputation.
You could just cut out the wheel wells with a saw and make them look decent and get rid of the rust(I dont know how bad it is). The fiberglass would probably fall out eventually unless there is something supporting it, like solid metal. And then if you plan to paint over that it would probably form bubbles in the paint. I guess anything is better than looking at rust...
Old 03-06-2005, 05:02 PM
i'm just looking for something that will stay looking decent for about 2 years though...i think this will be alright just 'til then..because i just want the truck to look alright..it don't have to be perfect..or anywhere near it really..but i want it to look decent...
Old 03-06-2005, 07:27 PM
71LTD390's Avatar
71LTD390 71LTD390 is offline
71LTD390 is starting off with a positive reputation.
Here's what i'd do. Cut out all of the loose flaky rust. Leave enough rusty metal there to support your bodywork. Coat all of the rusty area with your favorite rust paint (Rust Encapsulator, POR 15, etc.). Bend the edges of the rusted area inwards about one inch around. Then apply some fiberglass "sandwiches" to the area. (This is a layer of fiberglass mat with resin on each side.) The can of resin has the instructions. And yes the fiberglass will stick to the rust encapsulator-I can vouch for that. I'd never apply fiberglass to bare metal. Build the area up to contour. Sand it out roughly to match the contours. Then finish it with Bondo and prime and paint. Look in my gallery. See my dad's orange '74? I did it about 6 years ago and it is just starting to crack and pop though. From 20 feet away you'd never know. However on my '75 I am currently putting new metal in. I learned to weld and metal is a far superior repair. But if you are not going to keep it the call is up to you. Also, i've been trying the new "glue/rivet in" panel repair. Works well. I put my '75's cab corners on that way. Worked like a charm. But I can't confirm the durability yet. Always use fiberglass resin and matting to fill holes. The resin won't absorb water like body filler.
Considering 1989 F250..... Gregs69GTO 1999 to 2016 Super Duty 1 04-17-2008 03:13 PM
Bushwacker Fender Flares chapfr Excursion - King of SUVs 1 04-12-2006 11:02 AM
Epoxy Primer over Zero Rust? pshadwick Paint & Bodywork 2 05-03-2004 01:24 PM
Bedside panels PigFarmer Paint & Bodywork 5 03-27-2002 12:59 PM
1978 rear wheelwell rust repair cjben Paint & Bodywork 4 05-31-2001 05:50 PM
Tags
76, bronco, encapsulator, f150, fix, ford, paint, quick, rust, rusted, rusty, sell, truck, wells, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
