Replaced turn signal multi- switch
Did you remove the - battery cable before you swapped the switch out? Check the fuses in the central junction box there should be a 20 amp for brake and turns, and a 10 amp fuse for turn and hazzards.
Why did you have to replace the multifunction switch in the first place? Was the switch you replaced new, or was it out of a junk yard?
Freightrain
03-06-2014 09:29 AM
idealtrucks
08-05-2006 03:33 AM
