Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Ford V6 > 3.0L V6
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 03-05-2005, 01:04 AM
daedgar is starting off with a positive reputation.
Question Runs good on cold morning
I have a new flexfuel 3.0, and in the morning on the way to work this thing runs great, peppy, smoother. When I come home it is in the 70's and big differance, I notice I have to use a lot more pedal to get the thing going, whats up? Alot of good info here, Thanks
PS can I trick this thing to think it is cold?
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 03-05-2005, 10:12 AM
Buzzsaw's Avatar
Buzzsaw is starting off with a positive reputation.
Yo Daedgar,
Some very inexpensive things that I did to help my truck which is a 2000 3.0 Flex fuel Vulcan engine was to do the air box mod with a high flow filter, 180 thermostat, and the hot water bypass. Those three together cool the engine and intake a bit and get more cooler air flowing into the intake. I had a really bad pinging problem in the day with the AC on and the engine under load like going up hill. You can check to see if you need to do the throttle cable mod which will take the slack out of your throttle cable and will give you much better throttle response. The most expensive part of these mods was the high flow filter the rest just use scrap material and are easy mods for a beginner. All of these mods can be found by doing a search on the forums and you should be able to find pics describing the mods as well to help you along. Be warned, when you start making mods to your truck it can be extremely addicting and you'll find it hard to stop the fun once you start down that road. :>)
__________________
2005 Ford Explorer XLS
V6 4.0L SOHC FF Auto
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
