1997 ford f150 o2 sensors - Ford Truck Enthusiasts Forums
Old 03-05-2005, 01:21 AM
richyd richyd is offline
richyd is starting off with a positive reputation.
hello i have a 1997 ford f 150 with a 4.2 ltr v6 the check engine light came on so i took it to autozone and had the code pulled. They told me that the o2 sensor bank2 sensor 1 which is before the converter had a slow response so i checked the wiring and bought the o2 sensor. Theytold me bank 2 is the passenger side but well i changed the1st sensor on the passenger side and reset the code and drove the truck about 130 miles . and the light came back on. After reading a few posts. I think they told me wrong is the drivers side bank 2 or is the passenger side bank 2 I have a feeling if I continue to listen to autozone that im going to end up replacing all 4 at 60 bucks each any help with this problem would be greatly apreciated thanks in advance
Old 03-05-2005, 01:38 AM
97Centurion's Avatar
97Centurion 97Centurion is offline
Rub my Belly
97Centurion is gaining momentum as a positive member of FTE.97Centurion is gaining momentum as a positive member of FTE.
I'm always getting my banks mixed up but I do believe bank 2 is the drivers side. I do no that sensor 1 is the one before the cat. Probably wouldn't hurt to get another new one as the one you replaced probably wasn't far behind the bad one.
Old 03-05-2005, 09:41 AM
RoyalFord RoyalFord is offline
RoyalFord is starting off with a positive reputation.
Yes, bank 1 is the passenger side and Bank 2 is the drivers side.
Richyd, if you have doubts just ask us. We will be glad to help.
Old 03-06-2005, 08:49 AM
DICKLASER DICKLASER is offline
DICKLASER is starting off with a positive reputation.
Been There
I Had The Same Trouble Not To Long Ago. I Am Not A Mechanic But I Do Know By Spraying Wd40 On The Vacuum Lines When It Smoothes Out Thats Where The Leak Is. Mine Was That Hose At The End Of The Pcv That Goes Up Into The Carb. Where It Rests On Top Of The Engine The Heat Put A Small Hole In It. Four Bucks End Of Story. Hope It Helps, It Drove Me Nuts For Awhile.
Old 03-07-2005, 09:00 AM
5.4AZ4X4 5.4AZ4X4 is offline
5.4AZ4X4 is starting off with a positive reputation.
same problem, what gives!?!
I was just about to get on here and make the same kind of post.
I have a 2001 F-150 with a 5.4. I have 101,000 miles on it. I got the check engine light for both O2 sensors. Instead of playing the "replace the borken one" game I went ahead and dropped the coin on ALL 4 SENSORS, then reset the computer. I also replaced the fuel filter as well. Since I replaced them (3 days ago), I have done 2 long road trips using premium Techron fuel, still get the check engine light.
Can someone give me an idea why I would get the O2 sensor code 1 hour after I just put brand new sensors in??? I used OEM sensors from Ford, they ran about $400, so you can imagine why I would be a little mad. Install wasn't very fun either!!
Old 03-07-2005, 08:04 PM
Racerguy's Avatar
Racerguy Racerguy is offline
Racerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to behold
Usually O2 codes are a symptom of another problem. If there is a vacuum leak, dirty MAF sensor etc you can get codes for the O2s. Basically when you get an O2 code it means that the O2 is seeing a reading outside of what it thinks it should see, either too much or too little O2 in the exhaust.
Old 03-10-2005, 01:59 PM
o2 sensors
the code i was getting said slow response from o2 sensor bank 2 sensor 1 they told me it was the first sensor on the passenger side i replaced it and still the light came back on then i learned with your help that bank 2 is the drivers side i changed it and so far the light is staying off thanks a lot
Old 03-10-2005, 07:00 PM
Racerguy's Avatar
Good to hear that you got it cured
Old 03-10-2005, 08:50 PM
okieassassin okieassassin is offline
okieassassin is starting off with a positive reputation.
i have the same year but different engine, i have the 4.6l triton v8, wehre are all the sensor located at, does anybody know where i might get a diagram of these sensors
Old 03-15-2005, 01:17 PM
Gator4855 Gator4855 is offline
Gator4855 is starting off with a positive reputation.
I need to replace the 02 Sensor Bank 1 Sensor 2. I know Bank 1 is passenger side, but which Sensor is #2?
Old 03-15-2005, 01:24 PM
Merculous's Avatar
Merculous Merculous is offline
Merculous is starting off with a positive reputation.
#2 sensor is the one furthest away from the engine, after the cats.
Old 03-15-2005, 01:29 PM
Thanks....You must mean the one way down in the back...you know...the one that you need an extra joint in your arm to get to! It actually looks like it is easier to get to from underneath.
Old 03-15-2005, 11:34 PM
rmeidlinger rmeidlinger is offline
rmeidlinger is starting off with a positive reputation.
the easiest way and only way to replace the sensors in the exhaust manifolds is to remove the wheels and then take out the plastic inner fenders.6 screws and two push in fasteners.
think outside the box. both sensors can be changed in less than 45 minutes with a box end wrench, no special sensor wrenches or sockets required.
works for the starter also
Old 03-28-2005, 02:25 PM
kidzstang kidzstang is offline
kidzstang is starting off with a positive reputation.
I have an O2 sensor slow response also. Bank 1 Sensor 1 which means passenger side before the Cat; right? Now Racerguy; you say that O2 codes are symptoms of something else. My question is, does that hold for the "slow response" O2 code as well? If so I'll clean the MAF sensor and check the hoses first, otherwise I'll buy the O2 sensor.
Thanks in advance,
Jack
Old 03-28-2005, 03:38 PM
Racerguy's Avatar
Lean or rich O2 codes are usually caused by something else...but not always.
A P0133 or P0153 slow response code is quite often caused by a bad O2.
If you have access to a scan tool that lets you watch live data you can compare both front O2s and see if they switch the same. The one that has slow response is usually quite easy to spot if you can compare them both.
I would still start with cleaning the MAF and checking for vacuum leaks. If those both check out ok then you're probably safe to replace the O2.
Bank 1 is the bank with cylinder #1....the passenger's side. Sensor 1 is the one closest to the engine.
2010 F150 O2 Sensor replacement mgoodrich45 2009 - 2014 F150 3 12-05-2014 12:15 AM
O2 Sensor Question jhoobs Ranger & B-Series 2 10-11-2007 05:30 PM
o2 Sensor (Bank 1, Sensor 2) V10_Cougar Modular V10 (6.8l) 31 09-26-2007 01:12 PM
bank 1 oxygen sensor 96 explorer djn24 Explorer, Sport Trac, Mountaineer & Aviator 5 07-20-2004 07:41 PM
Check engine light 98 Ranger katdaddy Ranger & B-Series 3 10-13-2003 10:26 AM
Tags
1997, 2005, 42, 97, f150, ford, locations, o2, oxygen, passenger, sensor, sensors, side, troubleshoot, v6
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
