Yet another question- Why are they "nose down"?
Ok, the truck I looked at the other day (4x4 reg. cab 8 ft bed) had the heavy payload package which possibly could account for some of it, but it also was equiped with the "plow package". It still had that "jacked" look.
I do a LOT of hauling so I don't really mind this, but I just wondered why they sit that way. Does Ford have a deal with Daystar?
Also, does anyone know how much, if any, higher the fron and rear of the payload package and plow package 4x4 sits compared to the regular suspension?
Sorry to be a pain in the **** asking all these questions, but I'd really like to know more about this truck from guys who know something rather than a Ford salesman.
Thanks
Thanks
Two reason's.. One is aerodynamics. The nose being down like creates a wedge going through the air and reduces air drag under the vehicle..
The second reason has to do with getting bumper down so it will hit those saki burning go karts instead of you running over them.. Insurance co's actually give better rates on 04-05 150's because of it..
The first response in this thread was the correct one.
Aerodynamics!?!?
When's the last time you saw a RACE truck with its *** up in the air??
Bumper Height!?!
That's reaching! It can be argued that having the back end up could cause small or pointy nosed cars to go underneath the truck in a rear end collision. Ever seen a large cube/delivery van with the angle brackets welded on to prevent that from happening?
Bottom line is: If you want to carry the rated load in the back of the truck you gotta have the springs to support it. The springs needed to support the weight raise the back of the truck.
Bumper Height!?!
Monsta has nailed it. Frankly, I don't understand the debate. I have owned pickups built in 1949,1950,1956,1958,1960,1962,1963,1966,1967,1969, 1977 (that's all I can remember before coffee) made by the big three, and Jeep. They all sat up in the rear, unless you loaded them. My 56 3/4 ton Ford sat up like a stink bug until you dropped over 2000 pounds in it. Then it sat like my 2004. At 3500 lbs it was level. Even my almost trucks 1966 and 1977 El Caminos and 1969 Ranchero all stood up in the rear.
Before lowering became in fashion I never saw a truck that wasn't 'raked' to the front.
And trust me, nobody designed those older trucks for aerodynamics. Or safety.
Chris
Chris
