Valve Adjustment - Ford Truck Enthusiasts Forums
Valve Adjustment
Old 03-04-2005, 04:30 PM
ngneer ngneer is offline
ngneer is starting off with a positive reputation.
Valve Adjustment
New here folks, How do I adjust the valves on a 1990 2.3L 4 cyl. Thanks
Old 03-04-2005, 10:17 PM
IB Tim's Avatar
IB Tim IB Tim is online now
Site Administrator
IB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputation
...Welcome to Ford Truck Enthusiasts! If you have a minute check out the Guidelines, it will help you to navigate through and understand FTE.
Stick around someone will be by shortly to answer your question.
We are pleased you have chosen the best source for Fords!
Enjoy FTE
..See you on the boards.
Old 03-07-2005, 01:49 PM
Bart99GT Bart99GT is offline
Bart99GT is starting off with a positive reputation.
No adjustment is needed, you have hydraulic lash adjusters. If the valvetrain is noisy, one of them may need to be replaced or is gummed up. If you have a good OHC valve spring compresor (KD tools makes a great one that I use, I'll get the p/n off of it when I get home) you can try swapping them out yourself. They slide right out of the bores once you have removed the follower.
Old 03-07-2005, 04:26 PM
Thanks Bart99GT, I have just bought this truck and know zilch abt it. I'm use to smallblks. of a different make. I will learn what I can abt. this one. Info on the tool would be great, also could you direct me to some info to read up on pertaining to this procedure you talked abt. above, again, 4 cyl. is Chinese to me, thanks again
Old 03-08-2005, 11:39 AM
It is KD Tools 3087. Here's a link to an article on changing the valve guide seals on an SVO, but the same procedure applies for swapping out a bad lifter in our trucks, except you don't have to pull the valves out of the head. Just remove the follower, then pull the lash adjuster out of the head.
http://www.forced4.com/valveseals.html
Should i or is valve adjustment needed? JayzDaddy 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 2 05-29-2014 06:00 PM
Valve Adjustment fordflaresides Ford Inline Six, 200, 250, 4.9L / 300 0 11-23-2005 02:11 AM
adjusting valves? merc62 FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 4 03-09-2005 01:59 AM
300 I6 Valve Adjustment DrkPhanstm Ford Inline Six, 200, 250, 4.9L / 300 15 10-08-2002 06:52 PM
Valve Lash on a 390 with adjustable rockers banjopicker66 1961 - 1966 F-100 & Larger F-Series Trucks 7 05-26-2002 07:20 AM
Go Back   Ford Truck Enthusiasts Forums > >
Tags
150, 1986, 1990, 23, 23l, adjusment, adjuster, adjusting, adjustment, ford, lash, lifters, liter, ranger, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
