Does anyone know the company that a few years ago came out with an aluminum bellhousing that allowed a Mustang t-5 to bolt up to a 4.0 without any adapters. I saw it in a magazine a few years ago, a 4X4mag I believe. Now I can not find any information on it. Any help would be appreciated. Thanks!
I believe some mention of an adapter or something of that sort comes up every now and then. I doubt you'd find a sole bellhousing for the T5 to 4.0L, but they should help you.
Doesn't the 4.0 and the 2.3L four banger have the same bell pattern? If so you should be able to get one out of an SVO or turbo T-bird. You would need to get ahold of someone for a hydraulic slave though....
If that's the case, then get one from an '87 or '88 Turbo Coupe. Those are the only T-5's (to my knowledge) that had a hydraulic slave as OEM, so the bell should already be set up for it...
