b2200 smokes till warm - Ford Truck Enthusiasts Forums
Old 03-04-2005, 12:33 PM
88blkranger 88blkranger is offline
88blkranger is starting off with a positive reputation.
the truck is a 91 b2200 ex-cab. when you first start it up it pours out a thick cloud of smoke. I smelled the cloud and it's oil. it stops smoking when it gets warmed up. is this the valve guides and seals leaking oil after shut down?? this is the carbed 2.2L engine. I need to know if the repairs can be done at home or is there an additive to stop/slow the leak until i get the funds to have a shop redo a head for me.
Old 03-04-2005, 04:42 PM
Steina Steina is offline
CO River Rat
Steina is gaining momentum as a positive member of FTE.Steina is gaining momentum as a positive member of FTE.
I assume it's blue smoke? The best way to tell if it's valve guides or rings is to do a compression check, then squirt some oil in the plug holes and do another check. If the readings come up, the rings are worn; if not, it's the guides.
Steve
Old 03-04-2005, 05:41 PM
thanks
alot I was going to do that testing
Old 03-04-2005, 05:45 PM
CO River Rat
Good luck - hope it's the guides!
Steve
white smoke on start up? Meydawg51 1999 - 2003 7.3L Power Stroke Diesel 14 07-31-2015 10:57 AM
Power Loss? Rough Idle? Sputtering? LOOK HERE osu711 1994.5 - 1997 7.3L Power Stroke Diesel 2 01-12-2015 06:44 PM
Coil Pack vrs head gasket leak antman8759 1997 - 2003 F150 6 02-28-2011 07:39 PM
Why is my 2001 F-150 burning oil? tim5whs 1997 - 2003 F150 3 02-17-2008 08:40 PM
6.0 white/gray smoke at idle. cleebmx 6.0L Power Stroke Diesel 9 08-15-2007 04:10 PM
Go Back   Ford Truck Enthusiasts Forums > >
Tags
54, b2200, ford, lot, smokes, warm
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
