You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
I'm having some alignment woes. The tire that was on my passenger front was chewed up. Bad. The inside had hardly-worn tread, but the outside edge is probably...2/16 tread depth left. If that. Had it taken in for an alignment job today, and they looked at it and said the alignment was pretty spot on for a TTB Ford. I just had them rotate that tire to the back and call it could, we'll see with teh tire up there now. My question....any of you have any idea what is up? They said alignment was alright, everything checked out relatively. Good news is tie rods/TRE and ball joints are perfect. Pointed out OEM shocks though...so looks like its Ex. Procomp's for me sometime or something else when I get the chance.
how much were was on it when you bought the truck, maybe it was out at one time, and then realigned before you bought it?, either that or they are just so used to TTBs bieng out they think that is normal, if the tire that is on there now starts wearing badly find another shop, and have them check it.
__________________
Rob
Learn from your parents mistakes.......... Use birth control
check the bushings for the arm, the ones in the center. If they get worn, it will let it sit at bad angles. There are kits available for adjusting the camber, but they are a few bucks... I would go to someone who does alignment checks and have them check it out to be sure, and ask some questions as well to pick their brain as to why this is happening, because that is not normal wear for any suspension system.
__________________
the workhorse:86 F250 4x4 6.9 Diesel 4-spd, 4.10 axles
the other workhorse 92 F350 2wd crew cab,3.55 rear axle, 92 6bt Cummins, NV4500
the project: 78 F150 4x4 shortbed 351 auto Iowa Chapter leader, ASE certified parts specialist
Come on down and join us in the Iowa chapter, or your own local chapter!! Thanks, Roger
I'd check with another shop. I had problems with my truck, insides were wearing bad, but it was a straight axle.? Took it to our local mechanic that does most of our vehicles to align it, he said it was fine. My dad took it to work (Dick Witham in Waterloo) and had the guy there check it, and he got it sqared up and said the camber was off. Kinda surprising the difference in two ASE certified mechanics.
__________________ '08 F350 4x4 CCSB Lariat 6.4L PSD
DPF/EGR delete, KEM Tunes, Air bags, hitches and a big fuel tank.
Alot of places are really only going to check toe-in and center. Caster and camber are more than some places want to deal with. One place I took my old 64 straight axel didn't even know what I was talking about, let alone know how to check it!
__________________
I'm nothing more than words on your monitor.
