Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1987 - 1996 F150 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1987 - 1996 F150 And Larger F-Series Trucks SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 03-02-2005, 12:48 PM
RoadRash RoadRash is offline
RoadRash is starting off with a positive reputation.
Post F-series coil spring specs-- for your info
I have been answering alot of threads with regards to spring specs, so I figure I would post a list and possible make it a sticky. The specs are for 92-96 F-series. As you will see there are only a few coils that are actually used and YES they are interchangeable.
Included is the Moog/TRW P#.
Load and rate are in LBS.
F150 installed load rate free length
CC818 12.13" 1258 337 15.75"
CC820 12.13" 1428 366 16.19"
CC822 13.00" 1430 366 16.38"
CC824 13.00" 1442 366 16.94"
F250
CC844 12.75" 1557 630 15.40"
CC844S 13.00" 1759 629 15.79"
F350
BRONCO
CC818 12.13" 1258 337 15.79"
__________________
First
On
Race
Day
  #2 (permalink)
Old 11-22-2007, 10:13 PM
1989BIG6 1989BIG6 is offline
1989BIG6 is starting off with a positive reputation.
do you have the front coil spring specs for a 89 f150, 2wd?
thanks
__________________
'89 F-150 reg cab 4X2, BIG 6, 5spd, 3.08. 170k+ and going strong with nice system for some tunes.... delo 15w40 and new tires on the way...
  #3 (permalink)
Old 11-23-2007, 03:17 AM
Alvin in AZ Alvin in AZ is online now
Alvin in AZ is gaining momentum as a positive member of FTE.
Quote:
Yeah. :)
I've been wanting to ask questions about coil springs for months.
My '91 F150 has E0TA-5310-DC (MA) 's -on both sides- and wondering how they compare with the other stock springs that will fit it?
Alvin in AZ
  #4 (permalink)
Old 11-24-2007, 03:36 PM
1989 f150 would have either the CC818 coils or the 822 coils if it had V8 and a/c.
Alvin -- I would need more specs for your f150 eg.. 4x4, engine, cab
__________________
First
On
Race
Day
  #5 (permalink)
Old 12-28-2007, 09:26 PM
rustee90-150 rustee90-150 is offline
rustee90-150 is starting off with a positive reputation.
ive been wanting to lift the front end of my truck as well its a 1990 f150 302 5speed no ac reg cab 8 foot box could i get a 350 coil spring to put in it and what one would i want and would i have to change the shocks?
thnxs
  #6 (permalink)
Old 12-28-2007, 11:05 PM
fmr9 fmr9 is offline
fmr9 is gaining momentum as a positive member of FTE.
I have also been considering changing springs. My drivers rear is sagging, so the truck sits unleveled, plus the front is lower than the rear, like most trucks of this vintage.Local spring shop wants $250-300 to re-arch it to match the other side. I'm considering just buying both rear springs new, and replacing them myself.
I think I need to do what ever I'm going to do to the front, before I do anything to the rear. I read that just putting in new stock springs, should bring the front back up almost 2 inches, but then I read that someone had done it and been disappointed to just gain about 1/2 inch.
Looks like going with F350 springs would definitely raise the front a couple of inches, but probably stiffen the ride. I really don't want to make the ride any more harsh than it is. I replaced shocks, and went to alloy wheels with a MS tread. This lowered the unsprung weight, and improved the ride quite a bit, but it is still pretty harsh. Our streets are really bad because we freeze and thaw a couple of times a week all winter long. It just destroys the streets.
I don't plow, haul any serious weight, or pull a trailer. On rare occasion I will have 1000 lbs on it for a few miles. I'm not concerned about improving the hauling capacity. Just want it to sit more level, and not ride worse than it does now.
Buff is a 90 F150 regular cab, long bed, 4x4, air, 4.9 with the E4od. Truck weight is about 4600 lbs.
Any advice is appreciated.
Thanks Frank
__________________
BUFF " Butt Ugly F***ing Ford"
90 Ford 205,000 miles, 4.9, E4OD, 4X4, 3G alternator.
  #7 (permalink)
Old 12-29-2007, 02:30 PM
FMR9, it's possible to re-arch your own springs.
Got a sledge hammer and a hunk of RR rail? :)
My 10 pound worked great on the thin leaves but when it came to the 5/8" thick overloads, they needed something heavier. Talking about my '75 F150 here.
Bought a used 16 pound head and put a handle in it and it worked good.
Since all that and telling the story around, I was given a 20 pound sledge. :)
I also put a clamp on the front end of each overload spring that acts a little like a torque bar. Which helped with the dirt-road-hill-climbing.
http://www.panix.com/~alvinj/file12/clamp.jpg (heavy duty fuel hose)
http://www.panix.com/~alvinj/file12/ zerks.jpg (front clamp)
Talk about making the pickup ride better, the grease sure as heck does a great job of doing that! :)
Ever oil your leaf springs? :)
Most don't. :/
My '91 has plastic pads on all the leaves except for the overloads.
When i re-arch those to match the rest of the spring pack, I'll add a front clamp and zerks to them only.
For ~30 years I used STP in a squirt can and it's one of the messiest jobs there is and doesn't last long enough to be hardly worth it, even with STP.
I'm the opposite of most in wanting my pickup to ride "nice". :/
But oiling them helps prevent them from breaking and makes the pickup ride and handle more like new.
Re-arching the overloads to match the rest of the spring-pack will help keep the pickup from "bucking" too.
Alvin in AZ
  #8 (permalink)
Old 12-29-2007, 03:17 PM
westtntrucker's Avatar
westtntrucker westtntrucker is offline
westtntrucker has a very good reputation on FTE. westtntrucker has a very good reputation on FTE. westtntrucker has a very good reputation on FTE.
Great info. Thank you. Rep points sent!
  #9 (permalink)
Old 12-29-2007, 03:42 PM
Skandocious's Avatar
Skandocious Skandocious is offline
Skandocious is gaining momentum as a positive member of FTE. Skandocious is gaining momentum as a positive member of FTE.
Very nice list. I'll add this to our Sticky Suggestions thread.
  #10 (permalink)
Old 12-30-2007, 02:12 AM
Ok, A bit more coil info. 1980 to 96 All 4" diameter springs
All coils listed will work on any F100, 150, 250, and 350, with the exception of load capacity. eg: F100 springs in a F350 -- not wise or recommended.
The list below is the moog # followed by the same spring from other manufacturers.
MOOG Part # CC818 wire dia- .703"
--HUSKY# RV818
MOOG Part # CC820 wire dia- .718"
--HUSKY# RV820
MOOG Part # CC822 wire dia- .718"
--HUSKY# RV822
--ACDELCO# 45H1022
--SPICER# 5871022
MOOG Part # CC824 wire dia- .718"
--HUSKY# RV824
--ACDELCO# 45H1024
--SPICER# 5871024
MOOG Part # CC844 wire dia- .812"
--HUSKY# RV844
MOOG Part # CC844s wire dia- .812"
--ACDELCO# 45H1124
--SPICER# 5871124
Other spring options That I don't have complete specs on:
ACDELCO Part # 45H1026
SPICER Part # 5871026
--Wire Diameter=.72" Free Height=16.94" Load height=13"
ACDELCO Part # 45H1126
SPICER Part # 5871126
--Wire Diameter=.75" Free Height=19.54" Load height=13"
SPICER Part # 5871025
--Wire Diameter=.72" Free Height=16.38" Load height=13"
ACDELCO Part # 45H0209
SPICER Part # 5851209 for diesel
--Diameter=4.05" Wire Diameter=.875" Free Height=15.38" Load height=12"
__________________
First
On
Race
Day
  #11 (permalink)
Old 12-30-2007, 02:26 AM
Rustee -- You would not need new shocks for the 1" to 2" you would get from running the cc844 springs. I wouldn't run the cc844s (severe duty) as the extra srping rate and 200 pound aside extra capacity would kill you on anything but a glassy smooth road.
Rustee AND FMR
The spicer spring Part # 5871126 with slightly larger wire dia and 3" more free length then a standard spring may be the way to go BUT I don't know the load capacity and spring rate to say that 100%. And with out that info I can't even guess home much lift you would get.
__________________
First
On
Race
Day
  #12 (permalink)
Old 12-30-2007, 10:46 AM
ok thanks alot
  #13 (permalink)
Old 01-01-2008, 05:14 PM
alexjp91 alexjp91 is offline
alexjp91 is starting off with a positive reputation.
so i could use f-350 coils on mine instead of having to buy lift springs? i have an 83 f150 302 regalr cab 4wd no a/c dual shocks.
__________________
1983 Ford F-150 4WD. 5.0L 302.
  #14 (permalink)
Old 01-02-2008, 05:38 PM
Depends on how much lift your looking for. Yes 350/250 springs will work and gain you about 1" and a bit., great for leveling out the truck if you got a heavy front bumper or winch.
__________________
First
On
Race
Day
  #15 (permalink)
Old 01-02-2008, 05:44 PM
cool. i tried the cc822s but they didnt help and i returned them for cc844. how much would this help lift it but would the ride suffer?
also do u have any tips for taking out and putting in new coils? i had ome trouble getting mine out and the cc822s in.
thanks
__________________
Tags
5871124 , 822 , cc820 , cc822 , coil , ford , husky , moog , part , rate , rv820 , specs , spring , truck , trw
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
