Y block truck oil pan needed - Ford Truck Enthusiasts Forums
Old 03-01-2005, 09:34 PM
Sixoh's Avatar
Sixoh Sixoh is offline
Sixoh is starting off with a positive reputation.
Hey,
I already put a "wanted" thing in the classifieds, but I like to cut to the chase and ask the gang! I scored a running 272 (with issues, of course) for my truck, and am in the process of rebuilding it. The engine is a '57 out of a car (yes, with the ECZ-G heads, YAY!).
Anyhow, since it's a car, the oil pan is wrong and I need one for a truck. I am the lucky owner of not one but THREE car oil pans! DOH!
Shane
Old 03-01-2005, 11:14 PM
My58Ford My58Ford is offline
My58Ford is starting off with a positive reputation.
John Mummert has them listed on his website under "used parts".
40 bucks.
ford-y-block.com/usedparts.htm
Old 03-02-2005, 09:42 AM
brewster1 brewster1 is offline
brewster1 is starting off with a positive reputation.
I ran a Y car oil pan in my 60 for years. Used it on the farm and the pan never hit the axle. Fits up to the truck timing cover same as truck oil pan. No problem mechanically.
If you buy a truck oil pan make sure you get the oil pickup tube that goes with it.
jt
Old 03-02-2005, 12:15 PM
Sixoh's Avatar
My situation is that I'm lowering the truck. The front is down 3" and will go another 2-3" before it's all said and done. The rear end is also coming down a healthy 6 - 8". That's where my concern is for needing a truck sump.
Old 03-03-2005, 12:11 AM
Col Flashman's Avatar
Col Flashman Col Flashman is offline
Col Flashman has a very good reputation on FTE.Col Flashman has a very good reputation on FTE.Col Flashman has a very good reputation on FTE.
Sioux
There are Several 292 Pans on e-Bay as I type this.
Cheers
Flashy
Old 03-03-2005, 10:13 AM
Sixoh's Avatar
Man, I can't find any...I looked under "y block" "292 oil pan" "Ford oil pan".
Old 11-16-2010, 12:00 PM
Lawrence Petty Lawrence Petty is offline
Lawrence Petty is starting off with a positive reputation.
Find more than one let me know, as am looking for one also.
Petty3377@msn.com
Old 11-16-2010, 06:00 PM
WALFORD'S 56 WALFORD'S 56 is offline
WALFORD'S 56 has a great reputation on FTE.WALFORD'S 56 has a great reputation on FTE.WALFORD'S 56 has a great reputation on FTE.WALFORD'S 56 has a great reputation on FTE.WALFORD'S 56 has a great reputation on FTE.WALFORD'S 56 has a great reputation on FTE.
I have several....but on engines, I am not using......hate to remove them but will if you cannot find any others.
Bill
Old 11-16-2010, 07:29 PM
FORD14TPU's Avatar
FORD14TPU FORD14TPU is offline
FORD14TPU is gaining momentum as a positive member of FTE.
try pearsons wrecking in pearsonville ca .. he only deals in 50s-60s-70s american cars and trucks and he ships world wide ,,, i've scored some good stuff from him in the past,,and it's all calif low/no rust stuff..i drive past him a couple times a yr and always make it a point to stop..
Old 01-13-2013, 04:18 PM
crazy56ford crazy56ford is offline
crazy56ford is starting off with a positive reputation.
RE; Truck oil pan
are you still looking for a pan?
Old 01-13-2013, 04:31 PM
ibuzzard's Avatar
ibuzzard ibuzzard is offline
Gone But Not Forgotten
ibuzzard has a great reputation on FTE.ibuzzard has a great reputation on FTE.ibuzzard has a great reputation on FTE.ibuzzard has a great reputation on FTE.
Bro, the thread is from 2005......
Old 01-13-2013, 04:53 PM
did not see that sorry, new to this one.
Old 01-13-2013, 04:58 PM
ibuzzard's Avatar
Aaawww, that's all right little fellow.....LOL . Welcome to FTE, by the way.
1997 F150 4.2L oil pan jprice1981 1997 - 2003 F150 2 05-14-2015 10:24 PM
390 Oil Pan Difference ryanf77 1967 - 1972 F-100 & Larger F-Series Trucks 3 03-24-2015 11:57 PM
(Newb) 93 F150 Oil pan gasket 6.9 BLUES 1987 - 1996 F150 & Larger F-Series Trucks 2 04-02-2014 01:21 AM
trouble removing oil pan on 1953 flathead jhaas63 1948 - 1956 F1, F100 & Larger F-Series Trucks 7 02-03-2013 08:58 PM
77 f150 4x4 351m oil pan question 93truck 1973 - 1979 F-100 & Larger F-Series Trucks 3 11-04-2010 11:27 PM
Tags
272, 312, assembly, block, buy, car, f100, ford, oil, oilpan, pan, pickup, sump, truck, yblock
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
