Join Our Site - Its free, quick and easy!
Click Here to join.
05-25-2005, 05:27 PM
How to Coil Springs, Big and small.
Here's and excellent "How to on Coiling Springs". Its something we need every day in this hobby, from horn cap springs to carb tension springs which are no longer availlable and cost to damn much to buy if you do find them.
http://home.earthlink.net/~bazillion/setup.html
ENJOY.
__________________
C U AL
07-03-2005, 10:27 PM
How to read your Spark plugs and what they tell
__________________
1946 1/2 ton with 305 cu in Y-block
1990 Ranger 4WD
07-03-2005, 11:32 PM
There is a listing at bigalslist.com this is quite a list of whole bunch of different stuff.
John
__________________
'01 Ranger ext cab...'93 Cougar(Better halfs car)...'40(apart for now) slowly going to be daily driver.
07-09-2005, 06:56 PM
Ford auto info and pictures
__________________
C U AL
07-28-2005, 11:17 PM
Installing P/U box and floor
__________________
C U AL
08-08-2005, 04:49 PM
__________________
C U AL
08-08-2005, 11:06 PM
Some of the links I posted I did not save. Just came across them and though someone else might be interested.
__________________
1990 Ranger 4WD
08-17-2005, 05:07 PM
How to Wind Springs
__________________
C U AL
08-22-2005, 02:46 PM
1983 F-150 rear gear
I have a 1983 F-150 4x4, no bolt rear. It is either an 8.8 or 9" rear. Tag has
FL B 2M09
L08 8 8S8 22A
Which rear gear do I have and how might I tell?
08-22-2005, 03:27 PM
Shug,
Try posting the question over on the 80-86 forum. You shouldnt have to wait long for an anwer.
__________________
1990 Ranger 4WD
09-13-2005, 05:29 PM
Street Rod Tech Articles
__________________
C U AL
09-20-2005, 04:35 PM
Dictionary of Hot Rod terms
Can't remember what something is called? Heard a term or name and want to know what it is? Like to brush up on your word power? Try this out:
http://100megsfree4.com/dictionary/
__________________
C U AL
10-11-2005, 05:40 PM
Links to Machinist and Hot Rod Links
This a ground floor listing of Hot Rod links, such as FTE, as well as a good selection to Machinist, sheet metal working, hot rod building links. Try it out.
http://www.crankshaftcoalition.com/forumlist.html
Find something interesting? Share it with other Members on this Board, add it to these links.
__________________
C U AL
10-11-2005, 08:04 PM
Tuning Holley 4Vs
__________________
1990 Ranger 4WD
10-16-2005, 02:12 PM
Hello!
Just wanted to say Hello-I'm a new kid on the block
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is On
