Adding Posi (or locker) 8.8 to my 97' 150 advise needed
My truck is a PIG on ice! It is a 97' 150 4.2 manual 4x2. I have decent radials on it, but the limited slip "one legger" has got me in snow trouble a number of times this year as well as in the field (hunting). My next one will be 4x4, but that won't be for a few years and I need a change NOW. Currently the truck has a 8.8 3.55 rear end. Cost is an issue, so my thought is to buy an 8.8 posi unit on ebay and have my local trusty mech. install it (what exact parts will I need?). From what I have read, these units tend to "wear" out with time, should I be thinking about an aftermarket locker? Should I stick with the 3.55 (fuel milage is important)? Please give me your solution for my delema.
Thanks, Chris
Thanks, Chris
the ones on ebay are fine. just dont pay to much for one. im thinking like around a hundred bucks. make sure that its a 31 spline unit and that there is a cutout for your ABS ring. mustangs and trucks have the same ring and pinion but different spline axles. mustangs come with 28 spline and trucks have 31 spline. it might be a good idea to get a posi rebuild kit. about 40-50 bucks. and if you have friends that have done anything similar, see if you can get your hands on some carrier shims. you might need them. ratech sells a shim kit for about 50 bucks i think but theyre not as good as factory shims. shims from 8.8(mustang gt or truck) and 7.5(mustang 4 or 6 cyl) rearends will work. shims from ford are about 17 a piece.
I installed an EATON POSI in my 2000 F1504WD last year. It made a big improvement in 2WD in the snow here in upstate NY. It also helps a lot on wet roads. It wasn't very hard to install. I did it on a Saturday afternoon.
You will need a dial indicator, dial caliper or micrometer and a way to press new carrier bearings on the new posi, plus a good set of sockets and wrenches The posi,shim kit and bearings cost about $450 shipped to my house. Info on how to do the job can be found on the net.
