Carpet/Seat Swap
Carpet/Seat Swap
I'm sure it has been asked before, but has anyone had any experience with putting in a carpet from an 87-91, as well as the seat? The truck I have found is an auto, so the carpet has no holes, so I would just have to make the cut outs for the trannt/t-case. Any comments? My truck is a 1978 4x4 4spd reg cab
The seats will not bolt right in, you have to take the mounting brackets off your old seat and take the brackets off the new seat, then you can bolt the old brackets on the new seat ( and the hole line up ), now it will bolt in just fine. I put two newer seat in my 78 crewcab and it made the truck look 100% better on the inside and also make a better place to sit.
I just put a carpet from a 1991 F-150 2wd into my 1978 F-150 4wd. There are a couple of loose spots, but it fits pretty well. You need to trim it around the seat belts/cab corner area. I just cut the hole for the shifter, and added a 4x4 shifter surround from a 1995 Dodge truck. Looks factory. Also installed a bench seat from a 1994 F-150. As stated before, you have to swap seat tracks, but it is a super easy job.
Steve S.
To many to mention.
Steve S.
To many to mention.
march
08-15-2013 09:39 PM
fatherdoug
General Automotive Discussion
01-29-2007 01:58 PM
