Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1987 - 1996 F150 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1987 - 1996 F150 & Larger F-Series Trucks 1987 - 1996 Ford F-150, F-250, F-350 and larger pickups - including the 1997 heavy-duty F250/F350+ trucksSPONSORED BY:
  #1 (permalink)
Old 02-28-2005, 05:59 PM
frdsforme frdsforme is offline
Garage is empty, add now
frdsforme is starting off with a positive reputation.
1995 f150 rear gas tank replacement
Hi Guys
I was just wondering what was involved in replacing the rear tank on my truck. It is something that can be done with little ease or will you run into labour intensive efforts requiring "special" tools. The shops here say about 2 hrs labour + cost of tank.(120cdn + 40/hr cdn = $220 cdn total)
Is it difficult to remove the old tank components, incld fuel pump, etc.
Does it in any way affect the operation/gas milage of the truck , only operating on the front tank. Will it create any vaccum problems, etc.
Tks
1995 F150 4X4 REG CAB, 300 IN LINE 6, 4.9 LITER, 164000KMS.
  #2 (permalink)
Old 02-28-2005, 06:21 PM
tex94F250's Avatar
tex94F250 tex94F250 is offline
tex94F250 is starting off with a positive reputation.
Arrow Fuel tank replacement
I've done the midship tank. It required a special tool ($4.95 or so) for the fuel line release and replacement clips once done and reconnecting. I've looked in the Haynes manual and it looks like about the same procedure. Just FYI there are some 38 gallon tanks available to replace this tank that would give you way more range as well. J.C. Whitney has them and is a forum sponsor. There are several methods to doing this, I did it from under the truck using a transmission jack and a 2x10. Some choose to remove the bed. If you're gonna replace the tank and all, I think I'd opt (?$ for your judgement) for the 38 gallon rear tank. I have my spare mounted in the bed anyway. I'll never crawl under the truck for a tire again, period.
__________________
Tex
'02 F150 Lariat SuperCrew; 5.4l; 4x4 (the '94's retired)
Member: Georgia & Texas Chapter
JOIN CLUB FTE -SUPPORT THE BOARDS!!
  #3 (permalink)
Old 02-28-2005, 07:09 PM
Tks for your comments. I will take them in to consideration.
  #4 (permalink)
Old 02-28-2005, 09:17 PM
plapczynski's Avatar
plapczynski plapczynski is offline
plapczynski is starting off with a positive reputation.
You should only need the fuel line tool previously mentioned as far as special tools. It's just a bear to lift. I drained all I could out and still had 3-4 gallons in the tank. Add on that the dirt and rust, it's pretty messy but can be done my one person. I put a flat furniture dolly under mine to help roll it.
__________________
1993 F150 XL - 300 - 5 Speed
1988 Bronco - 351W
www.ohiobees.com
  #5 (permalink)
Old 02-28-2005, 11:03 PM
sixstick94 sixstick94 is offline
sixstick94 is starting off with a positive reputation.
I replaced my rear tank, 2 months ago, if you have a reciever hitch it is a major pain and I would consider removing it if I had to do it again. The only special tool is the fuel line release tool. Other than that it was fairly straight-forward. If you live in the rust belt, some PB-blaster would be a great thing.
  #6 (permalink)
Old 03-04-2005, 09:57 AM
jlsahlen jlsahlen is offline
jlsahlen is starting off with a positive reputation.
i just used a tiny screwdriver on the clips, worked fine. hardest part is the rust on everything. i live in buffalo, they like to cover every road with more salt then snow. had to grind off the old bolts. the ring holding the fuel pump in was disintegrated too. took me 4 hours because of all the rust.
  #7 (permalink)
Old 03-04-2005, 10:36 AM
low92flareside low92flareside is offline
low92flareside is starting off with a positive reputation.
Fuel line tool, about 5 bucks. A good floor jack and 4 5/8 bolts. Lower the tank down, pull the pump/sender and the vacuum line. Done. While you have it down you should consider replacing the pump and sender.
  #8 (permalink)
Old 03-20-2005, 10:08 PM
87f150xlt 87f150xlt is offline
87f150xlt is starting off with a positive reputation.
I have to replace my fuel pump on rear tank sometime, should I drop the tank or should I take the bed off? Can I take the bed off by my self? I really don't have mussles around here. In salt belt in Indianapolis. if that makes any difference.
  #9 (permalink)
Old 03-21-2005, 04:41 AM
FordTracMan FordTracMan is offline
FordTracMan is starting off with a positive reputation.
I changed mine,F250,with hitch in place.Remove filler hose ,Sending unit wires and lines.CAUTION-be sure to use a brass punch[no sparks] if you do not have a spanner wrench for fuel pump/sending unit.Not a bad job at all,just dirty.Observe all safety precautions-safety goggles/glasses and such.
  #10 (permalink)
Old 03-21-2005, 05:56 AM
tex94F250's Avatar
Start now with application of penetrating oil on the strap nuts. Do it daily for a week if you can.
__________________
Tex
  #11 (permalink)
Old 03-21-2005, 07:58 AM
I guess I'll start lubing the strap studs, when I get this truck out of muddy area that is. Also this tank is full, any easy way to drain the tank? suck fuel out of fuel line? or just take off filler neck and pump out from the tank? Thanks,
  #12 (permalink)
Old 03-21-2005, 08:22 AM
mike L mike L is online now
mike L is starting off with a positive reputation.
You may want to crawl under and use a hand pressure washer to wash everything first. maybe a shop vac. Has the fuel pump been working ok on the rear tank, you may want to change the pump. I don't think you will every want to pull the tank out again. I had to cut the bolts off with a sawsall or something that won't cause sparks. You may want to get a few new bolts before you start. Tank should come with a gasket and locking ring for the pump.
__________________
1993 F-150 5.0 4x4
  #13 (permalink)
Old 03-21-2005, 08:25 AM
i siphoned it out with a plastic siphon pump and some tubing, lost a piece of tubing in the fill neck, but got it back when i dropped the tank. i just drove it the way it was for a while, then when the front tank was empty i transferred the fuel to the front. (and my snowmobile, lawnmower, weed whacker and whatever other containers i could find)
Tags
150, 1995, f150, fuel, gas, needed, rear, remove, replacing, taml, tank, tanks, tools
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
