Biodiesel in newer PSDs?
#62
you guys should all check out this article that showed up on msn.com this morning:
http://moneycentral.msn.com/content/...ar/P115218.asp
BD might finally be getting the attention it deserves.
#64
#65
biodiesel
I wish when people make comments like that they actually know what they are talking about. Ford won't void your warranty if you use biodiesel B2 or B5 and you can run highier but Ford has to prove that the Biodiesel caused the problem whatever it is.Which there hasn't been any proven damage by running B2 or B5.
When the diesel engine was invented it was designed to run on peanut oil. Diesel wanted an engine that the people that used it could grow their own fuel.It wasn't untill later that the fuel as we know of today was invented.The diesel engine can run on B100 or used cooking oil with no problems.
#66
#68
well if i was not the top ford mechanic in western canada then it would be fair to say i do not know what i am talking about but if u do not know me then dont judge me. I DO KNOW WHAT I AM TALKING ABOUT and the engine is fine the G2 injector produced by siemens will not handle the diesel also the one in the old 7.3 will fail also a HUEI injector is not designed to work with this type of a product and i also have a heavy duty friend who works for CATERPILLAR and they have the same problems with injectors and bio diesel . SO BEFORE YOU JUDGE A BOOK BY ITS COVER REMEBER YOU ARE JUST THE OPERATOR OF THE PRODUCT NOT THE ENGINEER AND FORD CAN AND WILL VOID WARRANTY IF BIO DIESEL IS PROVED TO BE CAUSE OF FAILURE .
#69
Wow hit a sore spot.The key word is PROVED .I think Canada has the same Biodiesel we get here and there hasn't been one PROVEN case of B2 or B5 injector problem.There has been problem with the injectors running B100.
<TABLE class=tborder cellSpacing=1 cellPadding=4 width="100%" align=center border=0><TBODY><TR title="Post 2605818" vAlign=top><TD class=alt1 align=middle width=125>fordDR</TD><TD class=alt2>these fuel systems are not designed to run on bio diesel and you WILL VOID YOU"RE WARRANTY if ford catches it in there also that is why the 5% rule Chrysler is the same way when i worked there</TD></TR></TBODY></TABLE>
Then answer this question Why does it say in my Ford owners manual that I can run up to B5 ? So they can void my warranty if I do ? So between your friend and you your telling me that a diesel engine isn't designed to run on Biodiesel if they have a Siemens or Huei injectors? I just want to make sure what I'm reading before I pass judgement.
#72
We're running B100 in our new 2004 F-450 Flatbed. Only at about 2000 miles so far, and will update as we go along.
At 1200 miles the fuel lifter pump was replaced by the dealer under warranty, even though they knew I was running B100, and they told me not to use biodiesel anymore. I directly asked them if they were blaming biodiesel for the failed pump and they wouldn't go that far. They did give me the old pump so I could take it to a diesel mechanic so they could take it apart to see if they could find out why it failed. I will update on this as soon as I find out any more info.
The warranty voiding fear mongering espoused by some is very annoying to me. I have never had a warranty issue with any of our vehicles, even though I am very open about using B100. And we have 15 B100 vehicles, and are adding over 13,000 miles per month. With over 350,000 total miles to date.
#73
At least in my case the warranty voiding fear is espoused by the dealerships themselves. My personal concern for running B100 is my own understanding of the chemical makeup of BD as well as seeing how precise the injectors are. I am very confident that if I switched to B100 right now I would have no problems with the engine or fuel delivery system. I'm convinced I will have falied injectors down the road though. So I for one don't relish the thought of replacing 8 injectors out of pocket since I'm sure FoMoCo WILL use B100 as an excuse to not warrant this work. At which point my recourse might be to take it up with the B100 supplier themself. But if their gas meets all the regulations than they have nothing to worry about.
Now one thing I have considered is whether or not there is a diesel fuel system cleaner that is so strong that I could run it through the system every month or so to remove any of the injector buildup caused by B100. If that were the case I would happily start out on B20 and move to higher levels from there.
#74
#75
Originally Posted by BaldGuy
I don't know of too many solvents that are as powerful and as universal as diesel #2.
The supposed problem with biodiesel and the 6.0L injectors is not that it fouls them, but that the conditions in the engine somehow polymerize something in the fuel and coat the injector tips with a plasticy goop. So running straight diesel isn't going to cure that. (I don't know of any 100% verifiable source for what, IF ANY, problems there really are with B100 in the 6.0L, that's just what I've heard. And it could have even been something wrong with one specific batch of biodiesel, not biodiesel in general...)
Duncan
