Heard of Mesa tires? (Goodyear?) - Ford Truck Enthusiasts Forums
Old 02-28-2005, 02:37 PM
e1p1's Avatar
e1p1 e1p1 is offline
e1p1 has a good reputation on FTE.e1p1 has a good reputation on FTE.e1p1 has a good reputation on FTE.
Truck: 93 F-150 SC LB 4x4
Tires: 31x10.5x15 LT
I'll be needing to replace my Bridgestone HT Duelers pretty soon, and I checked on Tirerack.com for reviews of current tires. Seems the Kumho HT's are well thought of and cheap.
Most of my driving is 2x4 going on errands, or hauling a trailer to the dump. My 4x4 is mostly used in highway snow and getting around in a soggy pasture, sometimes with a trailer. No real 4 wheelin anymore. So highway efficiency and comfort is a plus.
The guy at my local Big O tire store (who steered me right on shocks for the Lincoln) told me he had a better tire at a better price. It's called a Mesa which he claimed is built by Goodyear. Said it's quiet and roadworthy, but a bit more aggressive offroad if I need it. He put it somewhere the Bridgestone Dueler and the Kumho.
Anyone used these? Other opinions while we're at it?
Thanks,
Erik
Old 03-02-2005, 10:25 AM
e1p1's Avatar
just bumping this back up top...
Old 03-02-2005, 11:04 PM
wmcutter wmcutter is offline
wmcutter is starting off with a positive reputation.
Wish I could help but never heard of them. Good luck.
Old 11-02-2006, 01:12 PM
e1p1's Avatar
Bumping this back to top. Any Mesa users?...
Old 11-05-2006, 07:33 AM
Silent Bob Silent Bob is offline
Silent Bob is starting off with a positive reputation.
Thumbs down
Ended up with a pair on the back of mine. They wear and ride ok, but absolutely 0 traction when not on pavement- very narrow footprint.
they are coming off soon...
Old 11-05-2006, 01:02 PM
e1p1's Avatar
Thanks Bob...what size are they? Not sure if it matters, but I use 31x10.5x15.
Erik
Old 12-24-2006, 12:14 AM
e1p1's Avatar
Last bump...
Old 12-24-2006, 09:24 PM
PowerStrokeHD PowerStrokeHD is offline
PowerStrokeHD is a splendid one to beholdPowerStrokeHD is a splendid one to beholdPowerStrokeHD is a splendid one to beholdPowerStrokeHD is a splendid one to beholdPowerStrokeHD is a splendid one to beholdPowerStrokeHD is a splendid one to beholdPowerStrokeHD is a splendid one to behold
About the only thing I can tell you about Mesa tires is they are a brand of Cooper Tire, not Goodyear.
I just recently purchased a set of Pro Comp Xtreme A/T's which are also a Cooper Tire brand. I am very happy with these tires.
A friend of mine is running Cooper ATR's and is very happy.
So with this being said, I can not really give you a reason not to try the Mesa's.
Old 12-28-2006, 05:04 PM
rebocardo rebocardo is offline
rebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud of
Ask him about the BIG O BIGFOOT X/T, those have gotten good reviews before (granted 2-3 years ago). They look aggressive enough for mild off road use and siped enough for ice and snow use.
Old 01-25-2007, 06:49 PM
e1p1's Avatar
Ok, so I did an FTE public service and purchased the Mesa AP (all terrain) tires from Big O. So far they are good on the highway, very quiet and stick well on mountian curves, sidewalls seem stiff enough (load range C). Dry roads only so far, but I'll report back when it rains and after we go to Tahoe for some snow time. I'll see if I can find a muddy road too.
They look like they're well siped, and the tread blocks are similar to the Kumho AT's. They look like they ought to shed minor mud ok, with tapered walls on the tread blocks. Overall, they look and are described as a less aggressive AT/LT tire, good for guys like me who don't go mudding or deep snow but need something more aggressive than a SUV highway M&S, and don't want to sound like a 19 yr old kid going down the road...
The decision was informed more by bald tires and an empty wallet, and I did talk to some locals who had the Mesas and like 'em, including one Toyota owner who said they did great down in crappy Mexico roads. Four 31x10.5x15's cost $424 out the door.
Funny thing is the Santa Cruz Big O manager swears they are Goodyear made, but the Los Gatos owner thought they were Cooper, but couldn't be sure. Duh.
Old 10-17-2007, 09:16 PM
runn1n runn1n is offline
runn1n is starting off with a positive reputation.
have these on my ranger, good tires for the road and mud, just not so good on wet pavement. i slid across the road and into someones yard after it rained
Old 10-17-2007, 10:54 PM
mrshorty mrshorty is offline
mrshorty is gaining momentum as a positive member of FTE.
The BigO guys here said they were made by Cooper. I'd have to go find the link to the government web site, but the manufacturer (and plant, for that matter) are encoded in the DOT # that's on each tires sidewall. Let me see if I can find it (it's on another site).
Here's what I wrote:
Quote:
Originally Posted by MrShorty
I'm sure most of you are aware that off brand tires are really made by the big boys -- they just put a different name on them. Ever wondered how to tell who makes a given off-brand tire? Ever wondered how to tell where your name brand tires were made? Ever wondered how to tell when your tires were made? I did some research, and have figured out how to partially decode the DOT code so you can get this information. I didn't see this information posted here, so I thought I'd put it up in case anyone was interested.
1st locate the DOT code: It will usually be on only one side of the tire, down by the rim. If you don't see it on the outside as you have your tires mounted, it should be found on the inside. It will look like this:
DOT MC(XX XXXX) WKYR
as an example: I have a Firestone tire with this as its codeOT 8XHL xxx 3900
Here's what it means:
MC -- These first two characters after DOT designate the manufacturer/plant. Take these two characters and enter them into the DOT ID search field of this NHTSA search page http://www.nhtsa.dot.gov/cars/rules/manufacture/ For my example, it shows 8X as Bridgestone/Firestone in Graniteville, SC.
The X's are extra digits used by some manufacturers to identify individual tire lines and stuff. From what I can gather, these digits, when present, are only meaningful to the manufacturer.
The last four digits designate the week (WK) and year (YR) the tire was manufactured. I've seen some indication that older tires (pre-'99 or something) will sometimes only use 3 digits, where the first two indicate week, and the last one year. So a date code of 414 would be the 41st week of either 1994 or 1984. So, for my sample tire, it was made in the 39th week (late sept/early oct) of 2000.
Hopefully someone will find this information of interest. It can seem pretty trivial, but I enjoy finding trivial pieces of information like this.
Old 10-17-2007, 11:26 PM
e1p1's Avatar
Quote:
Oops!
Might have something to do with the size/weight of the vehicle. The Big O Mesa's are working well on my truck in rain or shine, but my truck is a 93 F-150 4x4 LB supercab, with a camper shell.
Now that we're seeing rain again, I'll have to go find that muddy pasture and give them a try there.
They got a little lumpy sitting for a month after my knee surgery this summer, but they smoothed out ok after a few miles.
Old 01-20-2009, 01:33 PM
TheVarmit TheVarmit is offline
TheVarmit is starting off with a positive reputation.
I know this is an old thread..but..Mesa tires are made by Cooper.
Old 03-04-2009, 01:48 PM
skaynekurtis skaynekurtis is offline
skaynekurtis is starting off with a positive reputation.
Mesa Tire update
I too just purchased a set of Mesa tires from Big-O...
Fantastic deal for those looking for a generic tire...out the door at $415!!
I'm hoping they perform as well as a brand name...my tire guy seems to think so. I read some of the posts here...and most were positive.
Tread pattern is substantial, but I hope they do well on slick Vegas city streets...coated with oil...after rain showers.
Great website...glad I bumped into it... aloha, kurt.
What Tires do you suggest? mrrish79 1987 - 1996 F150 & Larger F-Series Trucks 5 11-26-2013 12:42 PM
04 F-150 4x4 tire help x2of3x 2004 - 2008 F150 13 03-25-2012 03:26 PM
Pick- Pirelli Scorpion ATR, Firestone Destination AT or Bridgestone Dueler AT Revo RunNRhino Explorer, Sport Trac, Mountaineer & Aviator 7 10-20-2009 08:28 AM
Which tire REDFORDFX4 2004 - 2008 F150 19 11-26-2007 05:54 AM
Bridgestone Dueler A/T Revo 1Knight Brakes, Steering, Suspension, Tires, & Wheels 3 11-24-2006 07:39 PM
Tags
265, 70r16, ap, big, bigo, cooper, makes, mesa, picture, prices, review, sri, tbc, tire, tires
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
