PCV Vacuum leak at Intake -- cracked 90* rubber Elbow - Cheap and easy fix! - Ford Truck Enthusiasts Forums
Old 02-28-2005, 10:08 AM
mudinford's Avatar
mudinford mudinford is offline
mudinford is starting off with a positive reputation.
Exclamation PCV Vacuum leak at Intake -- cracked 90* rubber Elbow - Cheap and easy fix!
Howdy all! Though i would pass on some info of a cheap fix I figured out this weekend while doing spark plugs and a B1S1 O2S on a friends 5.4 expedition (shudder...).
I got it all done and test drove the truck....i found that the truck seemed to surge and want to stall. I also noted a strong hissing coming from under the hood. Vacuum leak! SO i ran my hand all around for a while and finally found where it was coming from. It was that little 90* rubber fitting that converts the 3/8 PCV Line to a lot bigger. Anyway, it is a weak spot for failure...and the rubber was very brittle. SO i though we were screwed as far as getting another fitting. We went to NAPA and inquired about a fix.....and like i though...none was offered...so i went into the back with the parts guy and looked at what he had to see if i could make anything work....then i saw a spark plug sitting on the wall. I noted that the plug side was a 90* rubber boot and the sizes were PERFECT for what i was looking for....so i bought the plug wire for $4 and pulled the boot off. I installed the hose back on the truck and it fit like it was meant to be! SO if you get a vacuum leak at the PCV fitting at the intake....just get a plug wire boot...and save yourself some cash!
Old 02-28-2005, 05:18 PM
LxMan1's Avatar
LxMan1 LxMan1 is offline
LxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant future
Yup, that's what I did on my 3.8 Windstar last year, used a 90 deg sparkplug boot. It hasn't failed yet
Old 03-05-2005, 12:05 AM
xallxforxchristx xallxforxchristx is offline
xallxforxchristx is starting off with a positive reputation.
huh, that's interesting. I just found out about that little bend tonight, so I'll probably check it sometime tomorrow or next week when I have time off from school for Spring Break. Thanks for suggesting the easy fix.
Old 07-24-2005, 10:27 PM
KE8BG KE8BG is offline
KE8BG is starting off with a positive reputation.
I just found the same elbow on the back side of my 1997 E150 5.4L.. I didn't notice the crack but I noticed that with the engine running the elbow was sucked into collapse.
I used a piece of 5/8" heater hose over a piece of 7/16" fueline with a hose clamp as a reducer. It seems to be running better now..
Old 07-30-2005, 10:20 PM
bigexpo bigexpo is offline
bigexpo is starting off with a positive reputation.
Can Anyone Take A Pic Of It Becasue I Have No Idea Where It Is Theres Like A Cagillion Hoses Under The Hood I Know Its Behind Eh Throttle Body And Thats It
Old 07-31-2005, 03:10 PM
LxMan1's Avatar
Just follow the hose from the PCV valve in the passengerside valve cover to the rear of the intake.
Old 08-05-2005, 01:40 AM
tb40nd tb40nd is offline
tb40nd is starting off with a positive reputation.
Quote:
i've seen a pic of this somewhere... when i find it i'll post it!
Old 08-05-2005, 03:01 AM
here it is...
http://www.azda.com/ford/
...this guy had the same problem so just read up and hopefully it'll be what you need.
laterz!
Old 08-07-2005, 08:52 PM
gmiller0737 gmiller0737 is offline
gmiller0737 is starting off with a positive reputation.
The Dorman Company is coming out with the boot only designed for the 5.4 pcv system
Old 08-13-2005, 05:38 PM
tj0911 tj0911 is offline
tj0911 is starting off with a positive reputation.
Just fixed mine too......I have a 97 f250 5.4L. Advanced Auto did not hae the 90 degree boot. They did however have one for a Chrysler that fit perfect. Got a new PCV while I was there. Total cost was $6.38!!!!!
Old 02-02-2006, 03:54 PM
KeithE524's Avatar
KeithE524 KeithE524 is offline
KeithE524 is starting off with a positive reputation.
I was searching for a similar problem on my 99 Expy 5.4L. The engine idles just fine, but if you press the accelerator hard (even in park) the engine stumbles. The picture below is what I have found so far. It is the elbow going into the side of the intake. Last year, I replaced a couple of COPs, so I cut the boot off one and used that as a replacement. I still have the problem, but I haven't checked the rear hoses yet.
Keith
Old 01-06-2008, 09:44 PM
jason8225 jason8225 is offline
jason8225 is starting off with a positive reputation.
About a year ago I did this fix, only I used the 5/8" heater hose over 3/8" fuel line... noticed the hissing noise back earlier last week. Checked it out today and discovered that the 5/8" heater hose had collapsed like it had too much suction.
I guess tomorrow I'll have to either get a spark plug boot, the Ford part, or below.
Here's a question - would this work to fix it?
http://www.napaonline.com/MasterPage...CV%20Connector
Looking at the website linked above, I noticed that my PCV valve does not have a "y", it just has the hose going directly to the back of the intake. Any ideas why that might be or what I might be missing? This was already "fixed" once before I bought the truck, so maybe the person that did something before hooked wherever the other half of that "Y" goes to something else for vacuum?
Old 01-07-2008, 05:54 AM
vze2sgxa vze2sgxa is offline
vze2sgxa is starting off with a positive reputation.
When replacing my plugs, I opted to pull the IAC and clean it, and took the opportunity since I was working the back of the engine anyway to inspect this hose and elbow. My was fine, but before I reinstalled it, I cleaned and lubricated the rubber elbow and the pcv end connector and valve cover grommet with silicon grease. I added extra protection to the elbow in back by wrapping it in heat-blocking tape (like you use on water pipes, the wrap-type) and covered that with tight rubber electrical tape. Ain't no heat in the back of the engine gonna crack that elbow now.
Old 01-07-2008, 12:58 PM
Quote:
Any input on the above?
I went ahead and ordered the Ford part, but not sure what I'm going to do with the extra connectors yet...
Old 01-08-2008, 06:50 PM
LxMan1's Avatar
I know the car 4.6L had a T there and draws vacuum from both sides of the intake for the PCV for some reason. The trucks only use one with a 90. Not sure what they have done to yours.
#8 5.4 Cylinder COP/Plug Change JWA 1968-2013 Full Size Vans 5 10-03-2016 08:56 PM
PVC Troubles rustybuttrusty 3.8 & 4.2L V6 0 04-13-2016 06:30 PM
Escape stuttering or misfiring on acceleration dborns Escape & Escape Hybrid 12 03-02-2016 07:51 PM
Aftermarket Rubber boots, grommets, plugs, etc..... crazy96863 1973 - 1979 F-100 & Larger F-Series Trucks 3 06-07-2012 02:00 AM
5.4 idle loping wasn't IAC alone bobby_rogers Modular V8 (4.6L, 5.4L) 1 09-19-2004 02:39 PM
Tags
2001, 2005, 46, 54, elbow, expedition, f150, fitting, ford, hose, iac, leak, pcv, replacement, rubber, triton, vacuum
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
