428ci 400ford
Actually, it isn't. We had a similar thread (https://www.ford-trucks.com/forums/s...98#post2428098) running a couple of weeks ago about the same issue. There was some debate here about the size of the bore being too large and I just threw in the 352 pistons as a possibility. I don't have any idea if they would fit and if they did, what would happen to compression and valve clearance. It was simply a random thought.
I still like the idea of a 335 series Boss 429 or Cobra Jet (4.06 bore, 4.15 stroke, 351 boss/CJ heads). Weight savings would be about 150 pounds over standard 429/460 motor and about 50+ pounds over an FE.
And, as 77_F150_4x4 pointed out, how about a 434 stroker kit already put together (http://www.strokerkits.com/351___400m.htm) for $1895.
Includes custom forged pistons for 9.5 compression, 4.200 stroke crank (custom grind and cam cut 400 crank), 6.250 Scat I-beam rods, rod and main bearings, and rings.
Tim is working on a stroker motor with a 4.25" Eagle forged crank, SBC H beam rods (6.25") and a forged 351M piston. These are all off-the-shelf parts. A 440 cubic inch stroker can be built with a +0.060 overbore. Add alloy heads, intake, etc and you have a lightweight big cube motor built for whatever. Did someone say supercharge?
Kopfenjager,
I see some good points in your postings. When I get some cash built up, I think I'm gonna build a 400 based big cube motor, and I'm gonna do it the right way- BIG BORE baby! I'm Planning a lightweight 4 inch windsor crank, Oliver small journal BBC rods, and custom pistons at 4.155 bore and really high compression. Over 150 lbs. off the nose, good power, and no one would ever expect it. This is sounding better all the time.
Originally Posted by There Goes The Neighborhood
Kopfenjager,
--J
now we are thinking! Sorry to hear about the blocks, I think its bad luck cause all I've done but 1 (1 out of 3 actualy) was bad and it was a mcc block and during the bad years. I think 4.155 is feasible with BBC396 sleeves and a copper head gasket. Remember though that the bore is finished something like .01 over the desired bore, gives space for rings. So the 4.155 bore gasket would overhang about .005 on each side of the bore, or all around the bore if that is eiaser to picture. I like the overbore idea with a massive stroke to be a awesome idea. it's hard to keep up with the weezers when they can buy a 4.2 inch bore block for a couple grand.
#29
#30
I have put the figures together for making the 400 a big bore. Problem I for see is to acheive the 4.125 bore starting point would require installing sleeves that would be with .005" of touching. Now the problem I see is the integreting of the deck of the block. When you start pulling 100 ft. lbs. of torque on the head bolts, is it going to move on the sleeve? The top is starting to look like swiss cheese. I have thought about a flanged sleeve if that would give any strength. Question is if you can all ready get 440 cubes simply by stroking it, is it worth all the labor, parts and risk "is it going to work" to get an extra 20 cubes?
