4R100 identification - Ford Truck Enthusiasts Forums
Old 02-27-2005, 08:35 PM
fishman002's Avatar
fishman002 fishman002 is offline
fishman002 is starting off with a positive reputation.
I recently purchased a used 4R100 from a salvage yard that came out of a 99 "Ford Econo RV Cutaway S/Duty", (according to the VIN and carfax). I have a 2000 F-350 Crew Cab SD. When I recieved the transmission from the yard, I noticed that it had a torque converter with 4 studs and mine has 6 studs. Other than the torque converter difference is there any other differences in the performance of this transmission behind a 7.3 powerstroke?
Old 02-28-2005, 10:11 AM
rclarke rclarke is offline
rclarke is gaining momentum as a positive member of FTE.
The 6 stud torque converter is for diesel only. If you check I think you will find that the transmission will not bolt to your diesel engine anyhow. Even if you could bolt the transmission up I would not use a gas transmission on a diesel.
Old 02-28-2005, 07:11 PM
fishman002's Avatar
Not true. The VIN (1FDWE30F4XHCxxxxx) on this transmission has an F in the 8th position indicating it came from a 7.3 PSD vehicle. 1FD (Ford Motor Company incomplete vehicle), W (10,001-14,000 GVRW with driver and front passenger air bags), E30 (Econoline 350 DRW), F ( 7.3L OHV DI turbo V8 Powerstroke diesel). Apparently, Ford did put 4 stud torque converter transmissions behind PSD's. The bell housing bolt pattern matches the block exactly and the housing is identical to the 6 stud transmission that I removed from the truck. 4R100's were used behind PSD's, F-150 Lightnings, and F-250's with V-10's I believe. My quesion is still the same, is this transmission weaker internally to one with a torque converter with 6 studs?
Old 03-01-2005, 12:00 AM
RichS RichS is offline
RichS is starting off with a positive reputation.
I believe that vans use a detuned 7.3 so they won't put out the same torque as an SD 7.3 so that might be why it is that way. I think I read it here.
Old 03-01-2005, 10:03 PM
fishman002's Avatar
You are correct. I checked the part number with a local Ford dealer today and that is what they told me.
help IDing Torque converters wastric 1997 - 2003 F150 0 09-05-2014 10:09 PM
Torque Converter Stud Pattern 1972RedNeck Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 1 02-06-2014 05:57 PM
upgraded torque converter Acameron19 1997 - 2003 F150 1 09-02-2013 03:55 AM
Problem with leaking between transsmision and converter ! Help ! rosol91 Clutch, Transmission, Differential, Axle & Transfer Case 13 07-22-2012 05:20 AM
4R70w to 4R100w conversion jwatsjold 1997 - 2003 F150 11 11-27-2004 12:08 PM
Tags
1999, 4r100, converter, diesel, differences, engines, ford, gas, identification, rv, search, stud, torque, transmission, v10
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
