Looking for air pump part... see inside - Ford Truck Enthusiasts Forums
New Hampshire Chapter Join Chapter Leader: 7283-F250
Old 02-26-2005, 02:33 PM
danwink danwink is offline
danwink is starting off with a positive reputation.
Hello all,
I am in the Portland area and in need of the H pipe (above the drivers side cylinder head) that connects to the air pump. I figured someone that has gone to headers may have one lying around. Checked the local boneyards to no success. I can send a picture of what I need if anyone has one.
1989 F250 351W
Thanks
Old 02-27-2005, 06:35 AM
dsldandually's Avatar
dsldandually dsldandually is offline
dsldandually is starting off with a positive reputation.
sounds like a dealer item did you check the boneyard in westbrook by smiling hill farm I've had good luck there before
Old 02-28-2005, 04:18 PM
7283-F250's Avatar
7283-F250 7283-F250 is online now
NH Chapter lean pawn
7283-F250 is a name known to all7283-F250 is a name known to all7283-F250 is a name known to all7283-F250 is a name known to all7283-F250 is a name known to all7283-F250 is a name known to all
So you need the pipe between the two exhaust manifolds or the part that comes off the pipe that the air pump hose connects to?
I got one of the screw things that goes on the pipe a few years ago at a parts store. If its the pipe your looking for I don't know. Possibly dealer or bone yard. Some yards will do a search and can possibly get one from another yard in another state(thats how I got a working air pump). I twisted mine trying to get the old screw off and used JB Weld to fix the hole I tore in mine and I than had to hack saw off the rest of the screw to get the new one on.
Good luck
Old 02-28-2005, 06:17 PM
dsldandually-- I did not check Westbrook- just Copp and another in North Yarmouth. I will try them.
7283-F250-- I think they connect to the exhaust manifold, it is an H pipe that sits up on top of the valley, to the drivers side (next to intake manifold).
I can get it from the dealer, but they only sell it as a whole replacement for $125, you can't just get the connector. Seems crazy to spend that kind of money. I did buy some JB Weld, that might be the solution.
Thanks for the help!!
Old 03-05-2005, 01:11 AM
fords8's Avatar
fords8 fords8 is offline
fords8 is gaining momentum as a positive member of FTE.
Mechanic in Portland area 70mazie Oregon Chapter 4 12-03-2014 01:46 AM
Mechanic wanted in Portland, OR 70mazie 1967 - 1972 F-100 & Larger F-Series Trucks 8 11-25-2014 06:07 PM
390 windage tray ras4434 1961 - 1966 F-100 & Larger F-Series Trucks 3 04-07-2009 07:27 PM
Good machine/rebuild shop in Portland, OR? Jodell Performance & General Engine Building 2 04-05-2008 01:31 PM
Portland Swap Meet dustinova Washington Chapter 0 04-09-2007 05:49 PM
Go Back   Ford Truck Enthusiasts Forums > >
Tags
air, pump
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
