ATS Propane - Ford Truck Enthusiasts Forums
ATS Propane
Old 02-26-2005, 01:37 PM
Andres Andres is offline
Andres is starting off with a positive reputation.
ATS Propane
Hello everyone,
I,m new to this forum and would like to get some feedback regarding a propane system for my 2003 6.0 4x2 Ex. Read an article about this package from ATS Diesel in TRUKINS SUV and boasted huge ivrease in HP/TRQ and 20 mpg (?). Hope this is true since family and I go to Disneyworld 2-3 times a year and drive 2 out of 3 visits from NJ.
Questions: What benefits can I expect / how safe is this option and what if any drawbacks/effects would it have on existing mods?
The following have been done:
Diablo chip
Egdebox
upgraded/larger oilpan
Trq converter
Airraid air
Magnaflow exhaust
3" lowered susp
20s all aound 285 front 305s rear
Dynoed at 412 RWHP BUT TRQ WAS ONLY AN ESTIMATION AT 800+
Ex runs great and hane no complaints whatsoever. But am really curious about the propane benefit. Any help would be gretaly appreciated. Semp Fi
Andres E Santalla
USMC (Retd)
Old 02-26-2005, 03:40 PM
haroldservice haroldservice is offline
haroldservice is starting off with a positive reputation.
Propane is not a fuel catalyst, it merely fires at a different rate than diesel. search the web for an excellent article about injection, i'll see if i can find it. (Trust a marine to want more firepower than he already has!
Old 02-26-2005, 05:08 PM
IB Tim's Avatar
IB Tim IB Tim is online now
Site Administrator
IB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputation
Old 02-26-2005, 05:35 PM
powershotone powershotone is offline
powershotone is starting off with a positive reputation.
Welcome! and thank you for your service to our country.
When used properly and for it's intended use, propane fumigation is a very safe and effective means of increasing torque, horsepower and fuel mileage. I have virtually the same modifications as you do, and run my Powershot system with the Predator on 65 for a daily driver with no EGT concerns at 440 hp or so. (see the dyno sheet in my gallery ) I see at least a 1-2 mpg increase, even when you consider the cost of the propane. An 8 gallon tank lasts about 1000-1200 miles of constant use.
The only drawback is that you run out.
Old 02-27-2005, 06:59 AM
obxdieseldoctor obxdieseldoctor is offline
obxdieseldoctor is starting off with a positive reputation.
3 local guys running lp on thier 6.0s.one has the bdog version and i installed it,the other 2 have power shot ones.all three of the trucks run very well and have extra power however one of the trucks is in the shop getting the entire motor replaced,not exactly sure what happened but i think the lp in his applicatrion helped finish it off.also i dont feel this person was careful...
Old 02-28-2005, 11:50 AM
F-250 diesel F-250 diesel is offline
F-250 diesel is starting off with a positive reputation.
now if u run the propane tank dry, is it bad for the engine or anything or no
Old 02-28-2005, 11:54 AM
jdadamsjr's Avatar
jdadamsjr jdadamsjr is offline
jdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputation
Saw a bit on 2 guys garage about snow performance and how it cools the intake charge, improves mpg, and actually HELPS the power... (so they say)
scroll down to the last promo on this page:
http://www.twoguysgarage.com/thisweek/
Old 02-28-2005, 03:52 PM
No, when the tank runs out, nothing happens, except you lose the power, and believe me, you are looking to get it back quick. Good thing the tank lasts a long time.
Old 02-28-2005, 03:58 PM
im suprised it lasts that long, does it matter whether you got your foot in it or no? and how much does it usually cost to fill it up when it goes empty?
Old 02-28-2005, 04:16 PM
bighoss550's Avatar
bighoss550 bighoss550 is offline
bighoss550 is starting off with a positive reputation.
20 lbs costs 13 bucks here
Old 02-28-2005, 04:56 PM
SpartanDieselTech's Avatar
SpartanDieselTech SpartanDieselTech is offline
Former Vendor
SpartanDieselTech is a name known to allSpartanDieselTech is a name known to allSpartanDieselTech is a name known to allSpartanDieselTech is a name known to allSpartanDieselTech is a name known to allSpartanDieselTech is a name known to all
Quote:
Powershot, are you running the system at 100% of its potential flow, or what setting do you run it on?
Old 02-28-2005, 08:23 PM
I only hit the maximum flow for my truck when I am at full boost. The amount of propane flow, varies (increases and decreases) as the boost increases and decreases. Mine starts at 5 psi, which is the stock setting. So under 5psi, nothing happens and as soon as I hit 5 , the propane comes on and continues to pull as long as the throttle is down. So the amount I get at 20 psi is not the amount I get at 5 or 10 or 15psi. It is very econmomical on propane usage that way and I can use it all the time to reap some mileage benefits as well.
MPG's vs HP/TRQ bookem15 3.0L Powerstroke Diesel 108 03-09-2011 06:28 PM
fuel economy andre cote 1999 to 2016 Super Duty 1 12-17-2008 02:20 PM
79 351M; mods to run on propane? fishindave11 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 2 04-22-2007 11:34 AM
hp/trq ratings & purchase questions jberylecrider 1999 - 2003 7.3L Power Stroke Diesel 28 01-03-2006 01:23 AM
should I stroke it? nitz Performance & General Engine Building 4 09-10-2004 08:42 AM
Tags
1000, 2000, 2005, 6l, andres, ats, benefits, power, powershot, propane, runs, santalla, shot, system, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
