How to remove top speed limiter - Ford Truck Enthusiasts Forums
Computer Chips & Tuners SPONSORED BY:
Old 02-25-2005, 07:06 PM
harleyd8 harleyd8 is offline
harleyd8 is starting off with a positive reputation.
I have a 02F150 with a 4.2 V-6 and 5-sp. This thing cuts out at about 95
mph. Scared the bejeezus out of me the first time it happened. I do not
need this to regularly speed but have actually needed the speed a few
times passing on the interstate and while in traffic in large cities(Atlanta)
Thanks for any help anyone can provide.
Old 02-26-2005, 11:43 AM
FTE Ken's Avatar
FTE Ken FTE Ken is offline
FTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputation
What's the 4 digit PCM code, from the white sticker on the passenger side door frame near the hingers? I can remove it with a Diablo or SCT chip/tuner.
Old 02-27-2005, 07:55 PM
Ken,
I have looked and can not find the code you refer to. I am looking on the sticker that
has the tire pressures on it. Is this the correct one. I can't look now because it is
raining but I will look tomorrow when it clears up. Thanks for the response.
Old 02-27-2005, 08:45 PM
ford5.8's Avatar
ford5.8 ford5.8 is offline
ford5.8 is starting off with a positive reputation.
The sticker is on the door ledge on the cab to the front of the pickup.
Old 03-02-2005, 11:12 AM
Mr. Payne,
I found the sticker thanks to ford5.8's help. Sorry for the delay.
The 4 digit code is EFK1
Thanks
Old 03-02-2005, 03:55 PM
Eric Brooks's Avatar
Eric Brooks Eric Brooks is offline
Eric Brooks is starting off with a positive reputation.
The EFK1 calibration shows a speed limiter at 127 MPH
Old 03-02-2005, 08:36 PM
Mr. Brooks,
Thanks for the reply. I am not sure what is going on with my truck then
because at about 96 to 98 mph it either cuts the ignition, the fuel, something
because everything gets very quiet until I drop about 3 to 5 mph and then
power comes back in. If I had the 127 cut out that would be perfect.
Is this something I should check with my dealer on? Can they verify and if
it is off will they reprogram? Again, thanks for everyones help!
Old 03-02-2005, 10:00 PM
LxMan1's Avatar
LxMan1 LxMan1 is offline
LxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant future
Maybe the speedo is wrong.
Old 03-03-2005, 09:52 AM
FTE Ken's Avatar
Actually, all F-150s are 95 or 105. It looks like the read we had was already raised by someone. Quite honestly, I've lived in Atlanta for 25 years I've yet to have a "need" to go faster than 95 mph.... just a "want" every now and then until I realized 5 minutes less time at home is better than being dead!
Small Block ZF 5 Speed Ebay Find 80ford100 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 1 12-21-2014 01:44 AM
Looking for waste oil WMO near Atlanta, Ga ninegeorge Bio-diesel, Propane & Alternative Diesel Engine Fuels 1 06-28-2014 01:23 PM
Anyone in Atlanta? Rasputin53 1967 - 1972 F-100 & Larger F-Series Trucks 1 05-21-2014 03:35 PM
Atlanta diesel mechanic needed catdaddyyy 1987 - 1996 F150 & Larger F-Series Trucks 1 04-14-2014 06:02 PM
Atlanta Newbie GAMIKE New Member Introductions 2 11-12-2013 04:54 PM
Tags
2006, 2010, 2011, clear, expedition, explorer, f150, ford, limiter, maximum, remove, rev, speed, top, trafic
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
