Power Steering pump... Easy Replace?
Hi all
I have a 95 Explorer and the power steering sounds like it is going out. It doesn't seem like a hard fix but I would like to know if there is anything special like bleeding the system, that needs to beone or a certain tool needed. Any advice would be greatly appreciated. Thanks
Originally Posted by marragtop
You will need a puller to pull the pulley off. Most parts stores carry for about $30. Some stores will lend it to you as well. Make sure you get one for a Ford and you tell them its for the PS pump. Other than that, no big deal.
Before you go spending the time and money... what are the symptoms? Leaks, sounds, performance?
The FTE crowd may have some simple (cheaper) ideas on how to deal with your problem if you can provide more information.
Also... the Haynes manual has a method for bleeding PS pumps (turn the wheels back and forth). Not too tough.
taylorjgreen
12-31-2012 04:49 PM
Blackwaterforge
10-25-2012 07:25 AM
kevinm55
01-24-2006 08:55 AM
chili97
06-29-2002 12:50 AM
gstein
01-23-2001 08:24 PM
