Go Back   Ford Truck Enthusiasts Forums > General > Garage and Workshop
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Garage and Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
Is F-150 Still King?
  #16 (permalink)
Old 02-24-2005, 08:34 AM
sancochojoe sancochojoe is offline
sancochojoe is starting off with a positive reputation.
MBDiagMan,
You said that with the mig, that I place the wire on the spot that I want to weld before pulling the trigger. I was always under the assumption that there is a small distance between the wire and the target when you pull the trigger. So you are saying it will fire up with the wire resting on the metal you want to weld????
  #17 (permalink)
Old 02-24-2005, 08:46 AM
Aftrmidnite Aftrmidnite is offline
Aftrmidnite is starting off with a positive reputation.
Check with you local Junior college, thats where I got welding my knowledge. Plus welding the under side of commercial kitchen counters. LOL
  #18 (permalink)
Old 02-24-2005, 09:00 AM
Old Fart Old Fart is offline
Old Fart is starting off with a positive reputation.
Assuming the Hobart is a "cold" gun (no electricity to the wire until you pull the trigger), start off by touching the wire to the work, then backing off about 1/8" (this is where the autodarkening helmet is your friend). Stinger is at an angle to the work (in both axis), so you should be able to see the wire vs. the work clearly.
As far as buying a helmet - go to a legitimate welding shop. This isn't a purchase IMHO for Harbor Freight.
__________________
Jeff
06 F350 4x4 SCrew
94 Jeep YJ (confused, partly Ford, Chevy, I-H and Dodge)
02 Boxster S
  #19 (permalink)
Old 02-24-2005, 10:24 AM
Rosati's Avatar
Rosati Rosati is offline
Rosati is starting off with a positive reputation.
Another suggestion on welding sheet metal, use .23 wire rather than .30. It will be easier to lay smaller wire. On sheetmetal, you never want to lay a bead longer then 3/8" at a time. htis will mimimize the warping. Also, move around the panel, do not weld end to end as suggested on the thicker material. you will burn through.
I am self taught on the mig welder and I can lay some nice beads. But I learned in shop class at school (20 years ago) with a stick welder so I had a clue as to what I was looking and listenening for while welding.
Everyone else is correct though, practice is key. The suggestion about the community college is a good one, I'm even contemplating it myself.
__________________
Rosati
64 F100 with a few upgrades.
  #20 (permalink)
Old 02-24-2005, 11:30 AM
maxcarnage maxcarnage is offline
maxcarnage is starting off with a positive reputation.
everybody here has made some solid suggestions....all I can suggest is to go out and pick up a bunch of scrap metal, grab your hood, a good pair of gloves, your new best friend (the welder) and start practicing....the auto darkening hoods are nice, but I actually prefer a regular hood with a nice big lense (easier to see with for me). I also tend to use a lighter shade when mig welding as opposed to arc welding.......and one more thing....if you have any exposed skin while welding, USE SUNSCREEN
  #21 (permalink)
Old 02-24-2005, 11:40 AM
gregj gregj is offline
gregj is starting off with a positive reputation.
I don't have an autodarkening helmet but I found that if I open up the garage door and work in direct sunlight I can see well enough to get started. When it's cloudy I shine a halogen shoplight on the work from a few feet away and it provides just enough light to get started. You might have to wait a few seconds for your eyes to adjust but it works.
  #22 (permalink)
Old 02-24-2005, 05:42 PM
horsepuller's Avatar
horsepuller horsepuller is offline
horsepuller has a superb reputation horsepuller has a superb reputation horsepuller has a superb reputation horsepuller has a superb reputation horsepuller has a superb reputation horsepuller has a superb reputation horsepuller has a superb reputation horsepuller has a superb reputation horsepuller has a superb reputation horsepuller has a superb reputation horsepuller has a superb reputation
I'm not sure how much this applys to mig welding, so maybe one of you experienced MIG guys could verify this. But with stick welding I've followed this advice with great sucess:
When welding thin material, slant the work about 30 degrees and weld downhill. It welds cooler this way because there is less penetration. The opposite is true, welding uphill penetrates more and is more likely to burn through thin material.
__________________
Scott
Forum Guidelines
  #23 (permalink)
Old 02-24-2005, 07:10 PM
mark a.'s Avatar
mark a. mark a. is offline
mark a. is gaining momentum as a positive member of FTE. mark a. is gaining momentum as a positive member of FTE.
A mig won't weld through rust very well or any other crap for that matter. Make sure your pieces are very clean.
__________________
'79 F250 13" lift 42" Super Swampers
  #24 (permalink)
Old 02-24-2005, 07:18 PM
gbadgley gbadgley is offline
gbadgley is starting off with a positive reputation.
The basics for Mig & stick are the same. If you can stick weld, Mig will come very easy to you. I use both "push" and "pull" in Mig depending on what I'm welding. As they said before, start with heavier steel untill you get the feel then go to lighter steel. When you get a good feel try Aluminum - talk about having to move fast. Keep practicing you will get the feel of it, It's just like swimming you can read all the books but untill you get wet... Greg
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
