Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Computer Chips and Tuners
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 02-23-2005, 01:03 PM
BSHORT is starting off with a positive reputation.
Help! Code P1000 After Tune
I Just Installed The Tune From The Pred Into My 01' F150 5.4l. All Is Fine Except A Trouble Code P1000 (obdii System Test Incomplete) I Called Diablo And They Said That It Should Clear Itself After Driving. Well I'ts Been 40 Miles And It's Still There. What Is This And How Can I Clear It.
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 02-23-2005, 05:10 PM
FTE Ken's Avatar
Administrator
FTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputation
Be patient. Its a normal code that is set as a result of a computer reset. Disconnecting the battery will give the same code. Don't clear it, give it a few key cycles and a couple hundred miles. It will go away when the computer completes all its tests.
__________________
Ken Payne
Gone Fishing...
LACK OF PLANNING ON YOUR PART DOES NOT CONSTITUTE AN EMERGENCY ON MY PART.
2006 Roush F150 Project: Roush Supercharger, Troyer & My Tuning, 9lb pulley, Level 10 Trans, E-Fans, Oil Separator, Brandmotion GPS, BlueConnect Hands-Free Phone & iPod Direct Connect, Black Headlights & Taillights, Retrax Retractable Tonneau & more.
2004 F250 King Ranch Crewcab 4x4 6.0L PSD project: DP-Tuner Tuning and MBRP Stainless Dual Exhaust.
2000 Ranger Supercab XLT 3.0 V6 project: Bright Box, Mac Intake, Tonneau, my tuning.
RIP: 1967 & 1975 F100, looking for a 66 F100
  #3 (permalink)
Old 02-26-2005, 05:49 PM
I Found Out Later On That The Computer Needs To Test Itself Through A Series Of Things. I Had Initially Tried To Clear It, But It Wont Let You. All Is Well And Overall Drivability Is Much Better Than Stock. I Never Drive Quick And Rarely Even Push The Pedal To The Floor. Part Throttle Driving Has Been Positively Effected For The Better. Thanks For Your Reply, I Saw Where The Pred Has A List Of Normal Codes, Just The P1000 Was Not On It's List.
  #4 (permalink)
Old 02-26-2005, 11:20 PM
noFordguy is starting off with a positive reputation.
most trucks never get rid of that code even with over 200000 miles. you need to go though a drive cyle....... start engine with ambient temp lower than 40 degrees with a/c on, drive 0-60 with more than .5 throttle, keep at 60 for 5 miles, deacell to 35mph with no brake applied, 35 to 60 full throtle. it all in my scanner. basicaly its ok evey thing will be allright. p1000 is nothing to be worried about..
__________________
Sig violation.FTE
  #5 (permalink)
Old 02-26-2005, 11:56 PM
bosshoss is starting off with a positive reputation.
Like Ken said, it will clear on its own, just give it some time. Every time you disconnect the battery, or hit the clear codes on your scan tool, you will get this p1000 code till the computer re-runs its self test. If you have to get an emission state inspection done dont disconect the battery, or clear the codes just before you go in. They will reject the truck.
DP.
__________________
Dave Powell
  #6 (permalink)
Old 02-28-2005, 02:00 PM
R_Rider is starting off with a positive reputation.
Information below gained through painful experience.
The P1000 code will NOT go away if you are running the Predator pulley tune.
I drove mine for 5,000 miles, including exhaustively duplicating the EVAP drive cycle a dozen times. And the P1000 never cleared. Keep in mind that in many areas, such as central Tennessee, you cannot pass emissions if you are throwing a P1000. That means no license plate renewal... a BIG deal!!!
Finally I reinstalled the stock tune and the P1000 was gone in less than 100 miles. Remember... it hadn't cleared in FIVE THOUSAND miles with the Predator Pulley Tune.
We know that the pulley tune incorrectly reports the throttle position sensor WOT, PT and closed throttle status. You can observe this with the Predator. I theorize that this prevents the EVAP test from even starting, much less completing.
Good luck.
Sam
  #7 (permalink)
Old 02-28-2005, 02:53 PM
FTE Ken's Avatar
Administrator
This isn't a Lightning/Harley so there isn't a pulley or pulley tune to worry about.
__________________
Ken Payne
Gone Fishing...
  #8 (permalink)
Old 02-28-2005, 05:15 PM
Question
Quote:
Ack!
OK I'll read first next time!!! Can you tell I was scarred by the experience?
Sam "P1000 on the brain"
  #9 (permalink)
Old 03-01-2005, 08:42 AM
Eric Brooks's Avatar
Eric Brooks is starting off with a positive reputation.
Thats odd, on my 03 Cobra, with a pulley and the Predator tune, it went away after a few days of driving.
__________________
Diablosport and SCT Tuner @ MotorHaven.com
-2003 Sonic Blue Cobra (618HP / 530TQ) - SCT Tuned!
Kenne Bell 2.2L Blowzilla
  #10 (permalink)
Old 03-01-2005, 02:39 PM
Quote:
Might be just the L tunes. Might be just the pulley tune.
I'll bet your TPC reads correctly on the Predator?
  #11 (permalink)
Old 05-05-2005, 03:01 AM
hc130flyboy is starting off with a positive reputation.
My 2000 F250 with a 5.4 had the predator program in it and I drove from AZ to Dallas and back and STILL has the P1000!!! I took the tune out of the truck and I am trying to get it to throw a code so I can diagnose a misfire of some sorts.
  #12 (permalink)
Old 05-29-2005, 10:24 PM
redrumybronco is starting off with a positive reputation.
I was wondering what that code was for.... well now that I know, one question: Will the PCM process other codes while it waits for the P1000 to clear itself? (not that I expect to see any trouble codes, nor that I want to for that matter) And if so, will any codes show along side the P1000? Flyboy states that after driving several hundred miles that the code never went away...
  #13 (permalink)
Old 06-02-2005, 06:21 PM
FTE Ken's Avatar
Administrator
Yes, the PCM processes other codes. Its constantly checking conditions. Some set immediately and some take time. You can get other codes while this one is set. I'm not sure what condition is causing the P1000 to stay on for him, its extremely unusual.
__________________
Ken Payne
Gone Fishing...
  #14 (permalink)
Old 06-03-2005, 06:55 AM
The latest predator tunes don't (for me) have the "Persistant P1000" problem.
  #15 (permalink)
Old 06-04-2005, 12:29 AM
another question: is the DAT just for Cobra and Lightning? I tried it and it does'nt work either...
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
