2002 Sport Trac Rear Door's won't open
Both of my rear doors will not open from the inside of my sport trac. I have checked the child safety locks and they are not engaged. My daughter used to pull on the door handles before the doors were unlocked and I suspect that she broke something in the door by doing this. Does anyone have any suggestions on how to fix this? Both doors did not break at the same time, they broke about 6 months apart. Thanks
Rear Door Problem
Originally Posted by OverHeight
Had the same problem on my wifes 02 sport trac, handles broke on the inside. Fixed under warranty!
Gen 1 and 2 Explorers are notorious for the inside rear door handles breaking. Happens when someone tries to open the door when the door is locked. Doesn't happen in the front because the front doors unlock when the handle is pulled. If you have the same handles as the Explorers then the fix is pretty easy. Remove the interior door panels and replace the cheap plastic door handles. About $20 from the dealer or $12 or $13 on the Net.
Mason
Mason
EXPLORER INSIDE DOOR HANDLE REPLACE
YES, THE INSIDE DOOR HANDLES (ESPCIALLY THE REAR) BREAK EASILY WHEN THE CHILD LOCKS ARE LEFT ON AND SOMEONE TRIES TO OPEN THE DOOR FROM THE INSIDE. THE PLASTIC GEAR TOOTH INSIDE THE HANDEL BREAKS OFF. I HAVE CHANGED A TOTAL OF 3 ON MY 1997 EXPLORERS AND DID NOT HAVE TO REMOVE THE DOOR PANEL. POP OFF THE HANDLE TRIM WITH A SMALL FLAT BLADE SCREWDRIVER, REMOVE 2 BOLTS, TWIST ASSY AND DISENGAGE ROD, REMOVE HANDLE ASSY. INSTALL IS REVERSE OF REMOVAL. 5 MINUTE JOB TOPS!
ProudFordMan
06-11-2015 06:33 AM
Jeffrey w
08-25-2014 09:58 PM
brytruckguy
07-08-2014 10:39 PM
Nitroman
08-17-2010 01:43 AM
