Steering wheel play
Old 02-23-2005, 06:40 AM
tvvbsn's Avatar
tvvbsn
tvvbsn is offline
Steering wheel play
I noticed the other day that my steering wheel has side to side play and play up and down in the steering column. It moves about 1/4 inch each direction. The column itself doesn't move, but the steering wheel moves inside the column. Also the cruise control lights do not light up, and the OD light on the shifter column is off and on at random times, doesn't blink. Is there a bearing at the top of the column that can be replaced? And if so how difficult of an undertaking would this be?
Thanks
Tim
Old 02-23-2005, 07:45 AM
fixer1's Avatar
fixer1
fixer1 is offline
Is This A Tilt Steering Wheel??
Old 02-23-2005, 09:51 AM
tvvbsn's Avatar
tvvbsn
tvvbsn is offline
Yea its a tilt steering wheel, but there isn't any play in the part that tilts, just the wheel itself.
Its like the person that had the vehicle before me used the steering wheel as a handle to help himself up into the truck every time he got in it and put too much sideload on the steering wheel. It seems that there is a bearing at the top that is worn out and that the steering shaft wore through the wires that light up the cruise control switches.
I've never seen anything like this before in any other vehicle.
I took of the airbag and checked how well the actual steering wheel is attached to the steering shaft, and it is very tight, there isn't any play between the actual wheel and the shaft, the whole shaft moves inside the column with the wheel.
I don't know if I made that clear as mud, but ask questions if needed to clear things up.
Thanks
Tim
Old 03-28-2005, 09:42 PM
65stangy's Avatar
65stangy
65stangy is offline
Did you do any good on this problem?? I have the exact same thing with my 97 F250 with cruise and tilt, and was trying to figure out how to proceed with it. I pulled my steering wheel and took a look, but chickened out before I got it apart any further without knowing what I was doing, or what part I may need.
Regards,
Loren
Old 03-29-2005, 08:10 AM
IB Tim's Avatar
IB Tim
IB Tim is offline
Site Administrator
65stang...Welcome to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old 03-29-2005, 10:06 PM
bradk's Avatar
bradk
bradk is offline
I have a 98 f150 with tilt. I just replaced all 3 bearings last weekend in mine. They only cost $25cad for the 3 of them. I had a lot more play like 1/2 inch and they were grinding. I wasnt that hard just time consuming and a quite a few parts to remove.I took my time 5 or 6 hours from start to finish. Its nice to have a diagram and a few instructions to help out. I had to pull the column right out and did all the disassembly on the bench all you need to remove the bearings is a few punch and a hammer and you need a 2 jaw puller to remove the steering wheel. Also it didnt look like it a first but the ignition cylinder and gear do have to come out and note the positon of the gear it was a bit of a problem to get it repositioned properly.
My cruise control lights didn't work either it turned out to be a bent pin on the clockspring connector at the steering wheel..
Hope this helps
Old 04-01-2005, 09:46 AM
tvvbsn's Avatar
tvvbsn
tvvbsn is offline
Bradk,
Did the parts come with diagrams? Or did you find them somewhere? I am thinking about tackling that problem this coming weekend when I don't need my vehicle for a few days along with ball joints, tie rod ends, and shocks. Are the parts just called steering column bearings?
thanks for the help
Tim
Old 04-01-2005, 11:14 AM
bradk's Avatar
bradk
bradk is offline
I used the diagram off my repair cd it also had step by step instructions with pictures I didn't really need them it was pretty straight forward. They also gave me a diagram at the dealer when I ordered the parts you might have to ask for it. If they dont give you one I can send you a couple. All I asked for was steering column bearings I replaced all three but i probally only needed the upper two.
Bruners4
02-09-2015 11:53 PM
tvannaman2000
1999 to 2016 Super Duty
08-18-2014 03:56 PM
RIKIL
19
06-17-2013 04:55 PM
RichardPerry
04-17-2012 01:46 PM
bishopgeer
12-21-2009 07:58 PM
Quick Reply: Steering wheel play
