D'OH!! *%^#$@* Factory gauges! - Ford Truck Enthusiasts Forums
Montana Chapter Join Chapter , Leader: Sailor_Roy
Old 02-23-2005, 02:46 AM
big hoss 29's Avatar
big hoss 29 big hoss 29 is offline
big hoss 29 has a great reputation on FTE.big hoss 29 has a great reputation on FTE.big hoss 29 has a great reputation on FTE.big hoss 29 has a great reputation on FTE.big hoss 29 has a great reputation on FTE.
Well, tonight it finally happened. For the last 2 weeks or so, I've noticed that my clutch has been soft and prone to chattering on me. I just thought it was the fact that my truck has 162,000 miles on it with I don't know how many miles on the clutch. Well, my friend and I were on our way home from Huntley about 10 miles from Billings when all of a sudden my engine started ticking on me. I thought it was an exhaust leak at first, but as we drove on, I realized it was a lifter. I pulled into a gas station and prayed I didn't hurt the engine too bad.
When I checked the oil, I was surprised to se the dipstick bone dry! This surprised me because I just checked it 3 days ago and put a quart in, and the factory gauge was right in the middle of "Normal" the whole time I was driving tonight. Meanwhile, I noticed a 10" puddle of oil on the ground right in between the tranny and engine.
My friend looked under the truck and looked in the inspection slot and told me my flywheel was covered in oil. Well, I'm no scholar, but I do regognize a bad rear main seal when this happens. The worst part is, from the time we heard the lifters ticking until I could pull over was about 4 or 5 miles. I know this probably isn't enough time to do some serious damage to an engine, but it still hurt it, I just know my luck!. Then on top of that, I put 5 quarts of oil in, at a $1.99 a quart, but then it leaked 1 quart out on the 4 mile drive home.
So as it stands, the only thing that has me irked is the fact that my gauges read normal the whole time. I have my Pontiac so I can drive that no problem, but now I have a spring project lined up. So Matt, if you read this, I might have some business for you for a rebuilt 460 pretty soon. I need to replace the clutch and rebuild the tranny to get rid of the 3rd gear synchro clash as well, so I better go find that money garden and harvest some cash or I'm going to have an 86 F-250 lawn decoration.
Old 02-23-2005, 10:43 AM
Matts72's Avatar
Matts72 Matts72 is offline
Matts72 has a good reputation on FTE.Matts72 has a good reputation on FTE.Matts72 has a good reputation on FTE.
It seems you just need a rear main seal... unless you wanna spend 1500 bucks... I don't mind.
I'd probably even help you put it in. I'm pretty sure its a two piece seal, which is pretty easy as far as rear main seals go.
anyhoo... lemme know.
Old 02-23-2005, 11:22 AM
Yeah, I'm gonna just put in a rear main seal for now, but I will have to get an engine sooner or later as it uses about 1-2 quarts a week, and until last night, it was blow-by that caused my oil loss. I'm just going to drive the Pontiac for a little while until warmer weather hits and I feel brave enough to change the rear main. I'm going to put a clutch in it at the same time so I don't have to seperate the tranny from the engine a second time. The funny thing is, I just got my income tax return back a week ago and spent it all getting parts for the Pontiac....D'OH!!
Old 02-23-2005, 12:01 PM
mtflat mtflat is offline
mtflat has a good reputation on FTE.mtflat has a good reputation on FTE.mtflat has a good reputation on FTE.
Hoss, sorry about that problem you've got. (otoh, 16 mpg is pretty good, right?) I have my flathead V8 in pieces - needed a front oil seal - then I got to thinking, since it's this far apart maybe I should put in new rear seal too, check the valves, rings, etc. It escalates on you................. Good luck with it.
Matt, related ? on 460's.
Can you get me a dipstick for an 89 4x4 F250 EFI? Mine is corroded bad up near the top.
NAPA guy told me they're difficult to find..........
Thanks man!
Tim
Old 02-23-2005, 09:47 PM
Matts72's Avatar
We don't stock them, but tomorrow I'll stop by a wrecking yard and see if they have one.
Yea... I'll see what I can do to get you a good deal on parts...
Old 03-01-2005, 12:59 AM
Well Matt, I found metal in the oil filter, so, yeah, I'm going to have to spend the $1500 before I can drive the beast again. It's going to be a little while so this is fair warning. I'm also going to be buying a Hay's, Mcleoud or Centerforce clutch kit. Do you know where I could get the flywheel turned at a good price?
Old 03-01-2005, 01:18 AM
Matts72's Avatar
Our Machine shop will do it for $25. We sell Hayes clutches too... Although, I don't think they are any better than our NGC brand of clutches, which are made by LuK.
If your block is still good, I think its better to rebuild yours, I'd even help you out, and you're going to get the very best.
Lifter tick that comes and goes? MAHinton Oil & Lubrication 12 02-02-2016 02:58 PM
460 backfire and misses nhellman1 Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 3 06-23-2011 03:19 PM
help identify ticking sound- 04 explorer 4.0 anello1960 Explorer, Sport Trac, Mountaineer & Aviator 5 05-17-2010 02:55 PM
Possible lifter tick? clouds51984 1987 - 1996 F150 & Larger F-Series Trucks 9 06-27-2004 10:36 PM
I'm a bit confused by this sound MAHinton FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 3 01-18-2002 05:08 PM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
