my idle is getting a bit rough
okay, so my idle is getting a little rough.
It's developed a bit of a lope, but not in a good way.
instead of a purr, she dips down a bit, and you can feel it vibrate the whole truck.
It's like this: vrrrrrVRRRRRvrrrrrrVRRRRRRvrrrrrrVRRRRR
do you guys know what i'm talkin' about?
My mpg's have gone down, and i'm losing power. But i've also got 20 inch rims now.
awhile back, i tried to pull codes, and it said that sensor2 on bank2, which to my understanding is the downstream o2sensor on pass. side. Anyhow, it wasn't reading anything. I pulled no codes, and not throwing a light.
Anyone have any ideas? Is it just the o2 sensor, or is it something else? Help me please!
Time for new plugs and wires.
Mine did the same thing as yours at about the same mileage.
Plugs and wires solved the problem.
FWIW - you can use the $1.50 copper plugs from Walmart (Champion or Autolite) gapped to approx .054. They work just as good as the platinum plugs, just don't last as long. Actually, I believe copper is a better conductor that platinum. Platinum is used because it lasts longer and the OEM can claim 100,000 mile tune-up intervals.
Pinging is the generic name (which also describes the sound made) given to the uncontroled combustion that occurs from time-to-time.
There are several different root causes that lead to detonation, preignition, and a few other forms of fuel/air mixture igniting before it is ignited by the spark plug.
It sounds a little like a "rattle" as if a few marbles were being rattled in a can. It can be virtually undetectable, or loud enough you can here it from across the street as a car drives by.
Modern engines have "knock sensors" which are actually piezo electric crystal sensors mounted to the engine block. These detect the abnormal vibrations caused by pinging and send a signal back to the computer, which then adjusts the timing, fuel-air mixture, and who knows what else, in an effort to minimize the occurance.
There's lots more involved, but that is a thumb nail sketch.
Cool guys, thanks!
I was planning on changing the plugs and wires soon, since i hit 70k.
But why did my downstream bank2 o2 sensor not show any readings on the code reader? The symptoms my coworker described (running rough, decrease in mpg) are prevalent as well
Awww dude am I going to have to replace plugs, wires, AND an o2 sensor?
I would have to go with the Seafoam...and a little against. Most people love the Seafoam as with that high of miles.
Tom used Seafoam on his truck, and it actually made his truck suffer GREATLY after using it, but he didn't hardly have any miles on his truck. He actually had to use a fuel additive over and over and little by little the problem fixed itself. Also, he was always in the mud!
Joseph,
Are you sure???
Seems like Tom's problems started when he had plug wires come loose and short out. ALso, he had been running Nitrous and colder plugs.
I think he tried Seafoam to little or no avail, but I'm not sure it actually caused his problems.
I seem to remember he finally diagnosed a suspected heavy carbon build up due to the plugs (too cold). Numerous treatments of fuel additive eventually cleared the build up and eliminated most all of the pinging problem.
I might be wrong, but seems like that is what I remembered.
Actually, I have never heard of anybody having problems due to Seafoam.
Are you sure???
Originally Posted by BrianA
Joseph,
Are you sure???
Are you sure???
okay, i get a SLIGHT pinging (rattling sound?) from the engine. I was going about 75-80 in 5th (i have no tach)
I think I've heard it all along, but thought that something was just rattling. It's so hard to try to diagnose pinging just by reading about it on the forums... And the word "ping" sounds high-pitched to me.
Anyhow, gonna change the plugs and wires soon then.
And about seafoam, i was reading that someone flooded his cylinders with it and got a misfire in #3 and #6.
Anyhow, I'll probably give it a shot. I still have to work my suspension, it's getting rediculous. I've basically killed my front shocks riding on the drop coil, and in turn (aside from the hydraulic bouncing actioun) my steering has soooo much play because the shocks are so soft....it sways left and right.
I have all the parts, just need a @#$%@^ day off.
And yeah, where is Tom?
-rman
-rman
Still haven't gotten around to it. The pinging, well I really need to listen to my truck to be certain.
If you describe something, and I listen for it, Im sure I'll hear it even if it isn't there. You could have described pinging as the sound of squirrel farts, and I would have heard it.....
Also, with my entire cab sound deadened, my intake, flowmaster, and the active San Diego Volcano, it's hard to even hear myself scream bloody murder.
The plugs/wires are next on my list....I'll be sure to keep all posted. I'm one of those lazy/lagging people...
cps123
1999 to 2016 Super Duty
25
01-14-2017 09:09 PM
crimson080
1997-2006 Expedition & Navigator
07-18-2016 09:09 AM
street591
13
02-17-2016 12:00 AM
tlk401
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
09-25-2006 08:12 AM
