Upfitter Switch Help - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 02-22-2005, 07:37 PM
climo climo is offline
climo is starting off with a positive reputation.
I have the 4 aux switches in my dash and was looking for some help. I was getting ready to install some o/r lights using the aux switches but somehow I lost power to the whole switch, none of the 4 light up when flipped on.
I checked every fuse related to the upfitter switch but still no luck. They were working ok so maybe I blew a fuse or something. Each sw has its own fuse number and then there is one upfitter control fuse but all fuses are good.
Does anyone know where I might look for the power wire that supplies the aux switches? I know the colors coming from the plug but I don't have the service manual.
I'm really surprised Ford made it tough to connect items to these switches. Upfitter switches are not even covered in my owners manual.
Old 02-22-2005, 07:48 PM
sriddle's Avatar
sriddle sriddle is offline
sriddle is starting off with a positive reputation.
I too was not happy with no info from Ford on the upfitter switch. I also thought it silly they have a AUX button on the Radio that I assumed would be a cool place to plug into. After I buy I find that it takes a special harness not available yet to do what I thought would be a simple RCA plug.
Old 02-22-2005, 08:07 PM
93-331-29PSI 93-331-29PSI is offline
93-331-29PSI has a good reputation on FTE.93-331-29PSI has a good reputation on FTE.
What is the OEM ford part number on your upfitter switches?
Old 02-22-2005, 08:29 PM
Fredvon4's Avatar
Fredvon4 Fredvon4 is offline
Fredvon4 has a good reputation on FTE.Fredvon4 has a good reputation on FTE.
Climo
Open your glove box all the way so it swings down to the floor. Look directly up and remove the cover on the black box. There are some fuses and relays for the upfitter control box there.
In your owners manual is info on exactly what positions the four upfitter fuses have in the Mian Circuit panel fuse block.
Be sure to not have more than 8 amp continous draw on either of the two small upfitter wires and no more than 22 amps continous on either of the two heavy upfitter wires.
Yes they are MAX rated at 10 amps and 30 amps but you need some over head to prevent blowing fuses and relays.
Old 02-22-2005, 08:31 PM
Slipperyrock Slipperyrock is offline
Slipperyrock is starting off with a positive reputation.
What is tough about hooking up to the upfitters? I was told the 4 wires located under the hood by the drivers hinge are the upfitter connection points. Just splice/solder to them and you have power. If the wires I mentioned are the wrong ones I am sure someone will be along shortly to correct me. I have not tried to hook mine up yet. As to why yours aren't working...sorry I can't help you there but something may have shorted out while you were making the connections???
Old 02-22-2005, 08:42 PM
Talking
Quote:
Originally Posted by Fredvon4
Climo
Perfect....exactly what I was looking for. I will check it in the am. Hopefully this will cure my problem. I'll post pics when I get a chance.
Old 02-22-2005, 08:43 PM
jello's Avatar
jello jello is offline
jello is starting off with a positive reputation.
The wires under the hood are not the upfitter switches.Those wires just go through the firewall.You can connect on either end so you don't have to run your own wires through the firewall for any accessories.
Old 02-22-2005, 08:47 PM
JimRietz's Avatar
JimRietz JimRietz is offline
JimRietz is starting off with a positive reputation.
Quote:
The 4 wires which you mention are only "pass through" wires. They go from one side of the firewall to the other. There are no connections on either end.
For some additional information about the Upfitter switches, check out this thread.
Jim
Old 02-22-2005, 08:50 PM
morcutt morcutt is offline
morcutt is starting off with a positive reputation.
Here is the schematic link again, if anyone needs it. I think that it's been posted a few times already.
https://www.fleet.ford.com/truckbbas/non-html/Q117.pdf
Old 02-22-2005, 08:53 PM
Thanks, I realize that the wires are not "switches". I was just pointing out that you tap into the circuit under the hood. I hadn't really thought of tapping into the fuse box for stuff that doesn't need to go through the firewall.
Old 02-22-2005, 09:08 PM
I started reading the link above...looks like I have a little more wiring to do than I thought. I was wondering why Ford would leave hot wires sitting under the hood un-protected. Thanks guys.
Old 02-22-2005, 09:29 PM
jello's Avatar
Slipperyrock
If we are talking about the same wires under the hood (red,black,blue,white) they are not live.If you look under your dash behind your fuse panel, you will see the same wires not connected to anything.You can use them as a connection through the firewall without running your own wires.
Old 02-22-2005, 10:55 PM
Thanks Jello, you saved me some time later on figureing out why my stuff doesn't have any power.
Old 02-23-2005, 07:01 AM
IB Tim's Avatar
IB Tim IB Tim is online now
Site Administrator
IB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputation
Also check this out
http://www.ford-trucks.com/forums/sh...d.php?t=303583
scroll down the page
Old 09-28-2008, 02:00 PM
jtment jtment is offline
jtment is starting off with a positive reputation.
In regards to these upfitter switched, I too have had an issue with all four wires being hot. With the engine running and all 4 switches in the on and lit position, there is no power at any of the but ends as described in the manual. Fuses are good including the 1 5 amper behind the glovebox. We decided to just run our own wires by tapping in right behind the upfitter switched. We now have our own switched power but am wondering if this might have created any other problem. Are the wires that are factory run with the blunt ends on the any different than simply running your own?
Thanks, John
2011 F250 - Trouble Shooting Upfitter Switches E077528 1999 to 2016 Super Duty 2 10-25-2014 04:00 PM
08 Upfitter Switches-NOT WORKING-Help.. 1FastGambler 1999 to 2016 Super Duty 5 02-23-2014 11:20 PM
02 upfitter install complete cef2lion 1999 - 2003 7.3L Power Stroke Diesel 28 08-17-2013 05:35 PM
Rigid l.e.d. lights to upfitter switches (wiring experts) 40 oz 1999 to 2016 Super Duty 13 10-28-2012 07:48 PM
2008 F450 upfitter switches dead firemech 1999 to 2016 Super Duty 5 10-30-2009 05:36 PM
Tags
2009, aux, auxiliary, duty, f150, f250, ford, nonhtml, q117pdf, super, switch, switches, truckbbas, upfitter, wwwfleetfordcom
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
