96 with 80-86 front cap
on
1 Post
First Welcome to FTE! Be sure to check out the Guidelines .
I have heard that you can put a 92-96 front clip on a 80-86 so I ASSUME you could do it the other way around. You will need to change the grill, fenders, hood, lights, etc. It should work.
Your best bet would be to find a donor truck where you can strip all the parts off. Just take your time and label your bolts; there are A LOT of them! Good luck!
-Matt
P.S. That would be cool.....a 80-86 Lightning!
-Matt
I've seen it done... it can be done but not without complications... you'll have to find a place to mount the airbox intake on the radiator sapport.. and the bumper mounts might need some work.. other than that it should fit. the front wheel wells won't match the rear wheel wells though.. 80-86 go in ..then out. 87-96 just curve out. but it's only obvious to major ford enthusiests.
Z-dog
Z-dog
dohc_chump
38
09-27-2010 10:05 PM
F-Tony
09-13-2010 05:07 AM
jeremywright
04-13-2005 11:59 PM
jeremywright
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
02-24-2005 03:57 PM
