Power window(SLOW) - Ford Truck Enthusiasts Forums
Power window(SLOW)
Old 02-22-2005, 01:44 PM
unluckylow's Avatar
unluckylow unluckylow is offline
unluckylow is starting off with a positive reputation.
Power window(SLOW)
Hey guys just wondering if any one had a problem with there power windows sticking. It seems if its hot out the windows go down real slow, but if its cool out no problem they go down perfect. Is there a grease or a kit to maybe fix the plastic wheels so as to stop the sticking.Thanks guys
Old 02-22-2005, 02:55 PM
Red Boat Red Boat is offline
Red Boat is starting off with a positive reputation.
I had the exact opposite problem-hot outside windows worked fast, cold outside windows worked slow. Since the truck was still under warranty took it to the stealership for them to charge me $75.00 to grease the window tracks, the next week it got cold and guess what...... took it back to the stealership they replaced my window motors but would not return the $75.00 because "they still needed to be lubed" yea right!! that was the last $$$ they will ever get from me.
Old 02-22-2005, 02:56 PM
ckal704's Avatar
ckal704 ckal704 is offline
ckal704 has much to be proud ofckal704 has much to be proud ofckal704 has much to be proud ofckal704 has much to be proud ofckal704 has much to be proud ofckal704 has much to be proud ofckal704 has much to be proud ofckal704 has much to be proud ofckal704 has much to be proud of
I recently read a how-to article in popular mechanics on the subject with suggestions for remedying various power window ailments. Mine are someqhat slow and I am planning on digging the copy out of my son's room sometime for tips.
He is 14, so finding the magazine isn't as easy as just going in there to get it. I may need S&R dogs to find it!
But, they might have that article online or vist your local library. I think it was published within the last 3-4 issues. Late 94 or early 95.
Old 03-01-2005, 05:34 AM
PWRPROD PWRPROD is offline
PWRPROD is starting off with a positive reputation.
Slow Windoes: Yes they need lube but it is the tracks and guides more often than not.
Use LPS 3 silicon spray and spray the channels with enough to get them wet all the way down in the door. Run the window up and down several times to disperse the lube. This needs to be done about once a year as the tracks dry out. This will save you a moter and other expensive parts that wear from stress.
PWRPROD
2001 Power Windows DavidnSusan 1999 to 2016 Super Duty 2 06-03-2014 11:37 AM
99 f250 power windows problems SpeedRebel09 1999 to 2016 Super Duty 7 01-23-2013 10:11 PM
Power window slow in cold weather PeterAL 1999 to 2016 Super Duty 6 02-01-2011 10:00 PM
Failing or weak power window in 93 Explorer wickware Explorer, Sport Trac, Mountaineer & Aviator 14 09-15-2004 03:33 AM
Power window brushes 8996EBBroncos Electrical Systems/Wiring 5 12-04-2002 02:40 PM
Tags
1999, 2001, cold, explorer, f150, f250, fix, ford, power, sebring, slow, sticking, truck, window, windows
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
