best stock heads for a 390 - Ford Truck Enthusiasts Forums
Old 02-22-2005, 12:11 PM
ktownford ktownford is offline
ktownford is starting off with a positive reputation.
I am building up a 390 motor and unfortunately can't afford edel heads but I am wondering if there is a significant difference in stock heads that would fit these fe blocks ? I've heard the 352 heads have bigger exhaust ports. Any info as always is appreciated.
ktownford
68 F250 4x4
390 np435, np205
rev cut dana 44
35" tires w/ 4" lift
Should throw a pic of this gal on here!
Old 02-23-2005, 08:54 AM
Six Niner Six Niner is offline
Six Niner is starting off with a positive reputation.
i think the stock head of choice around here is the c8ae-h or the d2. the d2 has hardened seats.
Old 02-23-2005, 12:08 PM
rusty70f100 rusty70f100 is offline
rusty70f100 is gaining momentum as a positive member of FTE.rusty70f100 is gaining momentum as a positive member of FTE.
If you're looking for more flow, C4AE's are your best bet. You will need to get hardened exhaust valve seats put in though. For an off-road, mud, or work truck, C8's or D2's work great.
Old 02-23-2005, 09:29 PM
ceetwarrior's Avatar
ceetwarrior ceetwarrior is offline
ceetwarrior is gaining momentum as a positive member of FTE.
What about C6AE?'s? What's the scoop on these?
Old 02-23-2005, 10:16 PM
Well, my book says they're standard 352, 390, 410, and 428 heads. 71.2 - 74.2cc chambers. Standard size ports and valves. You'll need hardened exhaust valve seats though, as with all but the D2 heads. The D2's had hardened seats but the hardening was a surface hardening of the head itself, and not very deep. So if they need more than a valve job or two, they'll need the hardened seats installed also.
Old 02-23-2005, 10:33 PM
Sweet, that's what came stock on my '67. They seem to flow good. I had them redone, they needed new exhaust valves, and I got hardend seats put in and swirl grinded the intake valves.
Old 02-23-2005, 11:45 PM
fordeverpower's Avatar
fordeverpower fordeverpower is offline
fordeverpower is starting off with a positive reputation.
imo i think getting some c8 or d2 and porting them, good valves, and 3 angle seats are the way to go. Or getting some 428 cj heads if you can find them.
Old 02-24-2005, 09:35 AM
strider9 strider9 is offline
strider9 is starting off with a positive reputation.
Speaking of heads, I have a 390/2V out of a 65 Galaxie 500 sitting in a 76F100
waiting for me to get off my butt and finish. While I haven't had a chance to look for casting numbers, it's a safe bet that they were designed for leaded gas. My question is this : how long before a steady diet of unleaded gives me problems ? I ask, as I put over 300,000 miles on a 73F100 with a 302/2V before I burnt 3 valves. Many thanks !
Old 02-24-2005, 09:58 AM
banjopicker66 banjopicker66 is offline
banjopicker66 has a very good reputation on FTE.banjopicker66 has a very good reputation on FTE.banjopicker66 has a very good reputation on FTE.
Strider: The "lead" in gas was used to reduce detonation or pinging, not to add lubrication.
I have run unleaded on my C8-AE heads with non-hardened seats for 150K miles, and I spun a bearing before I burned a valve.
Old 02-24-2005, 10:56 AM
The lead tends to form a layer on the valve seat. Once formed, you can go for quite a while on unleaded. However, one valve job and it's gone. After that, expect seats to start sinking in about 20,000 miles.
The reason is that the hot exhaust valve tends to micro-weld itself to the seat. This pulls off tiny chunks of the seat, and blows them out the exhaust. The lead prevents this. Remove the lead, and you remove the protection it provides. Hardened seats resist this micro-welding effect.
So get the hardened seats.
Old 02-25-2005, 12:05 PM
ford390gashog's Avatar
ford390gashog ford390gashog is offline
ford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to all
or run a lead subsitute but i have c8ae-h and they are great i polished them and did a 3 angle valve job on they and they had 110,000 on the original engine it came out of and only slight marks from not running leaded gas
Old 02-25-2005, 12:14 PM
Annihilator Annihilator is offline
Annihilator is starting off with a positive reputation.
I think that a good compromise between Edels, and 428CJ iron heads are the C1/C4 heads. With CJ size valves put in them along with hardened seats, and maybe some minor porting and polishing that you would pretty much have at least the equivalent if not better than a 428 CJ head (in terms of flow and cost). They also have a little bit smaller combustion chamber than CJ heads so you wouldn't have to mill them as much depending on your application. The C3 heads would be good to but have a little smaller kidney-bean shaped chamber that is like 67cc and they cost a little more because of that. The C1/C4 heads have the bigger D-shaped chamber that is supposed to be a little smaller than the CJ chambers (I think they average from 72cc to 76cc). Just my .02 cents though.
JC
NP435 power handling candoo Clutch, Transmission, Differential, Axle & Transfer Case 3 01-18-2015 10:30 PM
FE engine build help candoo FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 5 01-06-2015 10:18 AM
352 rebuild: which way to go? sammycooks 1961 - 1966 F-100 & Larger F-Series Trucks 17 07-18-2013 06:11 PM
correct thermostat temp for a 390 ktownford FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 8 12-24-2003 09:03 PM
Let's talk 360/390 cams for towing/hauling... Charles-65F350 FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 8 03-08-2001 12:25 PM
Tags
390, 428, c8ae, c8aeh, chamber, combustion, exhaust, fit, ford, heads, polished, polishing, safe, size, truck, unleaded
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
