Gas mileage - Ford Truck Enthusiasts Forums
Gas mileage
Old 02-21-2005, 11:20 PM
Rayf250 Rayf250 is offline
Rayf250 is starting off with a positive reputation.
Gas mileage
I have a 76 F-250 w/ 360 2bbl with headers and the four speed w/granny low also 4:10 gearing. the problem is that i am only getting 6 miles to the gallon city and 8 highway. i talked to my father and he sayed he used to get 12 mpg with his (same set up) i think the carb is over jeted and am planning on putting a edelbrock aluminum intake and a holley 600 cfm 4bbl hopefully gets better mpg.
Old 02-22-2005, 01:55 AM
WillyB's Avatar
WillyB WillyB is offline
WillyB has a great reputation on FTE.WillyB has a great reputation on FTE.WillyB has a great reputation on FTE.WillyB has a great reputation on FTE.
I can't see it getting any worse. And telling your wife that these performance parts will give you better mileage is fair - and might even be true if the parts you are replacing are defective.
If you want to improve your mileage buy a vacuum gauge and do a good tune up on your engine. Make sure you have good wires, the vacuum advance works and everything is adjusted right and that you have good vacuum at idle.
If your carb has too big a set of jets, buy a smaller size. Wouldn't hurt to rebuild the carb - but just getting the jets right will help.
You are geared too low for really good mileage on the highway, but you should be able to get 12. I get 15 out of a F250 with a stock 390, running a C6 and 354 rears.
Old 02-22-2005, 02:09 AM
fordeverpower's Avatar
fordeverpower fordeverpower is offline
fordeverpower is starting off with a positive reputation.
i am not surprised since you have 4.10 and a camper special. I have a 1979f150 4x4, 390,4bbl, c6, 3.50s, duals exhaust and i get the same mileage as you. I ran a long trip this winter and with a couple wot races in there i got 8.12 on the highway only. The truck may be capable of 9 mpg in the fall with a tailwind. I do think the 4bbl could help you as the primarys are smaller. Hell i bet electronic ignition will benefit you. Just steal a duraspark setup and install.
Old 02-22-2005, 10:05 AM
FORD352V8 FORD352V8 is offline
FORD352V8 is starting off with a positive reputation.
4bbl helps with mileage, if you keep your foot out of it! I get about 12 out of my 66 352 4v and headers.
Old 02-23-2005, 03:44 PM
Cap'n Tea Bag Cap'n Tea Bag is offline
Cap'n Tea Bag is starting off with a positive reputation.
Not to get off topic, but what do you mean when you say "4V" after the engine size?
Whats the difference between the 2V and 4V?
Old 02-23-2005, 05:10 PM
WillyB's Avatar
2 barrel carb is 2V, 4 barrel carb is 4V. Spme people also use bbl = barrel.
Old 02-23-2005, 06:26 PM
v is for venturi also called 2bbl or 4bbl. It doesn't mean valves. Todays modular motors it is the amount of valves per cylinder 2v, 3v ,4v but they typically add them all up when saying the motor like 32v 4.6 dohc cobra motor.
2venturi=2bbl motor
4venturi=4bbl motor
Old 02-23-2005, 06:35 PM
dave74-360bb dave74-360bb is offline
dave74-360bb is starting off with a positive reputation.
to get back to 12 mpg try giving the truck a complete tune up plugs,wires,cap,rotor(points),air filter,pcv,fuel filter,etc.etc.
Old 02-23-2005, 09:11 PM
Thanks guys
sorry to ask such a stupid question
Old 02-23-2005, 09:36 PM
WillyB's Avatar
Not a stupid question - we all are looking at gas mileage nowdays. And I have found that a well performing engine will give you both - power and gas mileage. If your engine is tuned correctly your milage has more to do with how you drive then anything else.
I would not put up with 6 MPG around town if for no other reason then the time lost always filling the tank.
and el cheapo reg gas is $2.07 a gal here!
Old 02-24-2005, 02:04 AM
71_4x4_390's Avatar
71_4x4_390 71_4x4_390 is offline
71_4x4_390 is starting off with a positive reputation.
In regards to gas milage and cheapo gas, does anyone think octane boost works??? It is the difference of night and day when I run 95 octane over the 87 swill in my 390.
Old 02-24-2005, 02:29 AM
octane boost is scam! been there done that and researched it. There was an interesting thread a long time ago about them. I think it was sunoco who did the tests. I would do a search for it. If you don't know sunococ makes racing gas and is nascars supplier.
Old 02-24-2005, 07:33 AM
71_4x4_390's Avatar
I did some research and a store bought bottle of octane boost will only boost the octane 2-3 points i.e. 91 to 91.2. Not really worth it. The usual ingredients are Toulene, Xylene and Methyl-tertiary-butyl-ether (MTBE). I think MTBE was outlawed? Anyway, one would have to mix to 10, 20 or 30% ratios to get any real results.
Bottom line: A little bottle of that stuff won't do the trick.
BTW: Bad gas milage+ FE engines= a fact of life
Old 02-24-2005, 09:59 AM
gtex's Avatar
gtex gtex is offline
gtex is gaining momentum as a positive member of FTE.
I agree, FEs don't get the best mileage. But. my high performance stroked 428, running a C6, Dana 60 with 4.10s, and 30 inch tires netted 10 mpg on the highway. So, he ought to get a little better than 8mpg.
Old 02-24-2005, 12:33 PM
rusty70f100 rusty70f100 is offline
rusty70f100 is gaining momentum as a positive member of FTE.rusty70f100 is gaining momentum as a positive member of FTE.
FE's dont have to get bad mileage. My old 360 got 15mpg on the highway, and the preliminary results show the new 390 getting similar mileage.
Gearing has a LOT to do with it. I talked to my brother last weekend, who informed me that my truck actually has 3.50 gears in it. I always thought it was 3.70. Oh well.
The slower you can turn the engine at highway speeds, the better it is for mileage. With that granny low you've got, you could probably get away with 3.50 or even 3.00 gears.
4 bbl to 2 bbl Salomon Trujillo 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 8 05-05-2013 04:20 PM
4bbl 351 w intake 71 F250 WTB - Parts & other 0 03-11-2013 05:25 PM
pros and cons of a 4 bbl on a 360 68 f250 1967 - 1972 F-100 & Larger F-Series Trucks 11 02-03-2013 02:50 PM
stock 2bbl intake vs 4bbl intake...difference?? icuhatn99 Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 1 02-05-2006 11:35 PM
351W: 2bbl or 4bbl? calazo Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 3 06-04-2004 04:12 PM
Tags
100, 1996, 353, 390, bb, dudley, engines, ford, gas, gearing, gtex, improve, milage, mileage, mtbe, ranger
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
