can't undo flywheel/torque converter bolts - Ford Truck Enthusiasts Forums
Old 02-21-2005, 09:33 AM
Snow-man Snow-man is offline
Snow-man is starting off with a positive reputation.
Angry can't undo flywheel/torque converter bolts
can't undo nuts on flywheel to torque converter, how do you stop flywheel from moving when removing nuts, got motor stripped, trans is supported, only loosened off top motor/trans bolts, is there a secret to getting these things off there bloody tight and flywheel keeps moving...
someones got to know the secret...
thanks guys...
Old 02-21-2005, 09:44 AM
Sycostang67's Avatar
Sycostang67 Sycostang67 is offline
Sycostang67 has a very good reputation on FTE.Sycostang67 has a very good reputation on FTE.Sycostang67 has a very good reputation on FTE.
Try getting a friend to hold a wrench on the balancer bolt, or maybe a strap wrench on the balancer itself.
Old 02-21-2005, 05:51 PM
kochy54 kochy54 is offline
kochy54 is starting off with a positive reputation.
Best way is to get an impact gun (electric or air). Just be careful not to round them off, or you'll be chiseling them off.
Carl
Old 02-21-2005, 06:53 PM
rainvest rainvest is offline
rainvest is starting off with a positive reputation.
There is a way to this that has worked for me in the past. I used a tire iron or big screw driver and locked up the fly wheel through the starter housing. Using the starter housing as a fulcrum you can rotate the fly wheel in much the same way as your starter turns the fly wheel. (It's a bit slow) You can also stop the fly wheel from turning using this same method. I used a six sided wrench to loosen the torque converter bolts. If the bolts are really tight you can tap them with a small ball peen hammer and the vibration will eventually break the nuts free. I have done it this way many times pulling Ford transmissions. This was one of my beginning steps:
1. starter
2. transmission dust cover
3. torque converter bolts
Then all the other stuff linkage, driveline, cross member, cable, cooling lines, on and on. I hope this helps.
Old 02-22-2005, 06:18 AM
nuts
literally...
bloody nuts...
thanks heaps guys used all methods and all worked, but what to do one of the suckers won't budge, and it's starting to round off to, is there any other last resort, before The Last Resort, THE GRINDER...
then do I just replace with bolts from another converter/flywheel?
Thanks again guys for your help...
Old 02-22-2005, 08:29 AM
ronclark ronclark is offline
ronclark is starting off with a positive reputation.
Try using a 6 point socket or wrench to remove them. Torque converters do not use bolts and nuts. They are studs on the converter. If you grind them off then you just brought another converter. If you round off the nuts so they can't be removed with a wrench, then your best bet to save the converter is to use a hammer and chisel and try to split the nuts to get them off. Remember whenreplacing the nuts that they are lock nuts.
Old 02-22-2005, 01:29 PM
nuts
thanks for that advice ron... I think I'll battle on before getting the grinder out... really appreciate the warning... thanks...
Old 02-23-2005, 12:29 PM
F150stepside F150stepside is offline
F150stepside is starting off with a positive reputation.
Try using some heat propane hand held torch heat bolt up then tap it with hammer then try to back off could have locking compound on it heat should break it down.
Old 02-23-2005, 10:40 PM
Mr. Finch Mr. Finch is offline
Mr. Finch is starting off with a positive reputation.
I have not had this problem with ford truck tansmisions, but in my aunts ford countour (it had a 4cylinder) I tried to split the nut (that ussually works), but I severly damaged the stud, and I was able to just press out the stud with a clamp, and then press in a new one. Just becouse they are studs, does not mean that they are "one with the torque converter" (LOL). I would look at what a junkyard or parts store has visible, and see if they are removable.
Good luck
Old 02-23-2005, 10:46 PM
By the way, for future use, you could either do like rainvest said and use a screwdriver ro hold the flywheel in place (I have done it, and it works great). But you could also buy a flywheel holder. If you can get it in their, it works great for thoes nuts, and when you go to remove the bolts that hold the flywheel on it does beutifully.
torque converter AOD papabills54 1948 - 1956 F1, F100 & Larger F-Series Trucks 2 11-14-2014 09:55 PM
Quick engine removal question.... acarter92 Performance & General Engine Building 1 09-13-2013 09:20 AM
Help! Torque converter nut stripped. bullkram 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 3 09-01-2010 10:16 AM
Clutch/DMF Write up. NewRed 1994.5 - 1997 7.3L Power Stroke Diesel 3 02-18-2009 10:34 PM
special tool to remove fuel filter deltarbb Modular V8 (4.6L, 5.4L) 2 09-05-2001 06:13 PM
Tags
bolt, bolting, bolts, converter, f150, flywheel, ford, moving, nut, remove, removing, rounded, torque, truck, turning
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
