Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 SVT Ford F150 Lightning, Roush, Saleen and other performance F150's SPONSORED BY:
  #1 (permalink)
Old 02-21-2005, 12:11 AM
Jasons03Harley Jasons03Harley is offline
Garage is empty, add now
Jasons03Harley is starting off with a positive reputation.
'03 Harley lowering/rims questions
I'm new to this forum, I just got ahold of an '03 Harley, silver black. It's already lowered in the back to level it out, but I want to put a little more drop on it. I was considering the Eibach pro kit, which gives it a 2/4.5" drop from stock. Any suggestions on how to switch out the hangers? I read about the shackles already. Any reviews on the eibach suspension or sugestions for others? Also, I wanted to run some 22" rims, 285/35/22 on it...will they fit, or will I need to stay with the 20"s? I figured this was the place to get the most advice from people with experiance.
Jason
  #2 (permalink)
Old 02-22-2005, 07:45 PM
Shift1 Shift1 is offline
Shift1 is starting off with a positive reputation.
For switching out the stock hangers, you first use a cutting wheel to make a cut across the top of each rivet, then use an air chisel to cut the heads off. Then you can pound out the rivets through the frame.
For the tires, you have guessed the right size of tire--they will fit. You can put on 295's in the rear.
  #3 (permalink)
Old 02-22-2005, 11:31 PM
so 22's will fit even with a 4.5" rear drop?
  #4 (permalink)
Old 02-25-2005, 08:21 AM
22's will fit with the 4/6 drop, as long as you get the 35 series tires.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
