Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 02-20-2005, 09:18 PM
TexsDixieDiesel TexsDixieDiesel is offline
Garage is empty, add now
TexsDixieDiesel is starting off with a positive reputation.
Do It Yerself Propane Injection on 7.3 IDI
I have briely read on "ZIGGSTERS" web page about a do it yourself Propane Injection. I WANNA DO IT. I just don't know exactly what parts to look for to begin the project. Anybody out there know a little more about what parts I need? Any comments on the whole project? DOES ANYBODY HAVE AN EMAIL I CAN REACH "ZIGGSTER" at?
  #2 (permalink)
Old 02-20-2005, 09:34 PM
RawPower's Avatar
RawPower RawPower is offline
RawPower has a very good reputation on FTE.RawPower has a very good reputation on FTE.RawPower has a very good reputation on FTE.RawPower has a very good reputation on FTE.
Is this the link you looked at?
http://www.members.shaw.ca/k2pilot/P...20article.html
If not, theres another one with some parts listed. If it is the same one, go to his home page- he used to have an email on there...
Ill soon be doing it myself...
  #3 (permalink)
Old 02-20-2005, 09:38 PM
yeah that's the one i looked at, and it does have a list of all the stuff, but i just don't know exactly what all that stuff is, and i don't know the first place to look for it all. I looked and looked, but couldn't find his email. I just got done looking at the post from the guy that is putting his own turbo on a 7.3 idi and i am going to try to find out some more about that too, that is something else i would like to do.
  #4 (permalink)
Old 02-20-2005, 11:47 PM
89ford73's Avatar
89ford73 89ford73 is offline
89ford73 is starting off with a positive reputation.
i put a holset 35 on my ford, i also tried the propane injection. i had very little luck with the proane injection on the n/a. it just made my motor clatter and smoke more with very little power gain. i have heard much better results than i had with my exeriment, i used a acetylene regulator, 75 bucks brand shiny new, a 4 gallon bottle of propane, 10 foot of 1/4 inch hose, and a short piece of copper 1/4 inch tubing with some holes drilled in it. i don't know what i did wrong, but sure didn't help me very much. i think my timing is set too fast for pane. your timing may be set a little slower and just right for it, i never did change my timing to see if there was a difference, but i did have a pretty good thread about it.
  #5 (permalink)
Old 02-20-2005, 11:51 PM
patriottow patriottow is offline
patriottow is starting off with a positive reputation.
Great info maybe I`ll try it.Keep us posted. Thanks
  #6 (permalink)
Old 02-20-2005, 11:55 PM
89ford73's Avatar
i made a propane injection!! 7.3 idi non turbo theres my link i think there are a few others also.
  #7 (permalink)
Old 02-21-2005, 01:57 AM
banks7.3 banks7.3 is offline
1991 Ford F-350
banks7.3 is starting off with a positive reputation.
after i put my ts performance propane kit on ($200.00 on ebay including all hoses fittings and tank brackets) i did some research on the internet. found out the regulator is a beam garretson t-60, found one for $89.33. and the lock-off switch is a model #fl-218-12v, unsure of mfg. for $60.30. 4psi balkamp pressure switch from napa part #701-1575 for $28.00 for turbo applications, add your fittings, hoses and tank, then your set. this regulator will run on liquid or vapor (the heater hose hooks up to it to vaporize the liquid). regulator is sealed (non-adjustable) type. the regulator is only a few dollars more than the acetylene regulator, with no need to adjust. the lock-off switch is for added saftey. hook it up to a toggle switch to stop the flow of propane from inside the cab.
  #8 (permalink)
Old 02-21-2005, 07:19 AM
Dave Sponaugle's Avatar
Dave Sponaugle Dave Sponaugle is offline
1997 Ford F-350
My Garage
Dave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to behold
You can find a lot of the stuff you need at a LPG dealer.
Another place for some of the parts will be a welding supply house.
An RV shop should be able to come up with some parts also.
I have been watching a lot of posts about this topic.
From what I have read either a two stage regulator or two seperate regulators work best. I think I will use two seperate regulators when I do this project. One to cut it down to like 10 PSI at the tank and another to cut it down to about 3 right before the intake.
The next thing that I see is you want the propane to start flowing at less than 1/2 throttle to maximize the MPG increase and keep the propane pressure low.
I also think a pyrometer would be required to keep from melting the motor.
This would be very important if you crank the fuel up to max the HP gain.
__________________
86 F250 HD 6.9 IDI ATS turbo "not exactly" stock 4x4 T19 BW1345 3.55LS both ends D60 front, 10.25" Sterling rear, ram air, dual stacks.
"I dig dirt"
FTE Guidelines
FTE Moderator IDI diesel forum
WV Chapter Member
  #9 (permalink)
Old 02-25-2005, 06:31 PM
dburke8088 dburke8088 is offline
dburke8088 is starting off with a positive reputation.
I have been wondering about installing a Pyrometer in my '93 7.3L. Where is a good location for such a device. Since I don't have turbo my exaust system dosen't have a fitting. So how far from the heads should it be installed?
  #10 (permalink)
Old 02-25-2005, 10:21 PM
89ford73's Avatar
i never could get my truck too hot, i ran propane, BLACK smoke, i put a turbo on it off a dodge cummins, and i have yet to hit over 1300 to the floor after about 2 minutes with 15 psi boost at 3500-4,000 rpm's, and 1200 is safe to run all day long, 1250 is safe for about 30 minutes before stuff starts melting, since aluminum melts at 1350, and with the oil squirters it keeps the pistons cool. i have seen a cummins run at 2,000* for a total of 2 minutes in a burnout contest before he got scurd and let off, blowing black smoke everywhere, it was quite a site to see.i have not heard of a ford idi that had anything over 1300 exhaust temps. i have seen people with turbos claim the hottest they can get it is 800-850 degrees, even one guy has a boat with a 7.3 in it and a turbo. i would tell you that a pyro is a waste of money since i alredy bought one, installed it, ran the motor hard as i could and never saw it get hot, so i just unhooked it and it's sittin in my closet right now. 150 bucks for a pyro that never sees anything too hot to worry about doesn't float my boat. but to answer your question, i would put the probe on the left exhaust pipe about 6-10 inches after the left manifold, thats where i had mine.
  #11 (permalink)
Old 02-25-2005, 11:07 PM
1997 Ford F-350
My Garage
Put the thermocouple in the exhaust manifold. Drivers side all the way to the back. I had the engine out when I installed mine. Drilled and tapped the manifold, thread the thermocouple right in there.
I can see 1200 in a very short time pulling a good grade empty. My fuel is not turned up and my truck is a little over 8000 pounds empty.
__________________
"I dig dirt"
FTE Guidelines
WV Chapter Member
  #12 (permalink)
Old 02-26-2005, 10:49 PM
Go Navy-Beat Army's Avatar
Go Navy-Beat Army Go Navy-Beat Army is offline
Go Navy-Beat Army is starting off with a positive reputation.
Ditto what 89ford73 says. Hottest my pyro ever reads is 1150. That's on a grade pulling my 12,000 lb trailer.
__________________
94 F-350 7.3 IDI CC SRW 4.10 E4OD Hypermax Turbo 3 1/2" Exhaust Soup bowl removed K&N Airfilter
82 MUSTANG 460 BRACKET RACER 10.29@130mph
65 MUSTANG 351W C-4
Tags
73, 73idi, 73l, beam, ebay, fl218, fl21812v, ford, garretson, idi, injection, kit, model, propane, turbo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
