What Octane? - Ford Truck Enthusiasts Forums
What Octane?
Old 02-20-2005, 06:42 PM
Dustin_86 Dustin_86 is offline
Dustin_86 is starting off with a positive reputation.
Question What Octane?
What fuel should I run in my 99 ZX2? The manual says it has 9.6:1 compression ratio, is that on a borderline 89 level? I want max power/fuel milage. My mom's truck has 9.25:1 and it runs like CRAP on 87oct (3.0) V6. It runs on 87 but.....?
Dustin
Old 02-22-2005, 04:41 PM
Bart99GT Bart99GT is offline
Bart99GT is starting off with a positive reputation.
Probably 87. You can't judge what kind of fuel to use on compression ratio alone. Older engines required higher octane fuels at higher compression ratios because of less efficient combustion chamber designs that didn't promote even combustion. Fuel and spark are also far better controlled than they were in older engines as well. Put all this together and you've got a higher compression engine that is less prone to detonation on a lower octane fuel.
The 3.0 V6 is an exception to the rule as Ford can't seem to fix the detonation problems that plague this engine. My guess is that the FFV calibration just doesn't get along well with 87 octane gas since any kind of Methanol blended gas is going to have a naturally higher octane. There is *supposed* to be a sensor in the fuel line so the EEC can tell when a methanol blend is being used and changes the calibration accordingly.
Go Back   Ford Truck Enthusiasts Forums > >
Tags
30, f250, ford, octane, truck, v6
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
