Tire Pressure on 2002 xls
That's just a recommendation for the stock tires and configuration. It's really a personal preference issue, but in or around 30psi(28-36) is where you will find the sweet spot on most applications with most tires. Added weight may require a little more pressure to maintain handling, braking, and ride characteristics, and front and rear balance in handling cna change with pressure differences front to rear. I found 30psi to be a little low on the stock tires for my liking, but run 29psi in my current set front and back, which seems to be the best compromise.
vid33nyc1
08-15-2011 09:02 PM
Trickedout420
03-06-2007 12:29 AM
FordBuilder101
17
04-13-2005 03:06 PM
