Signs of a bad MAP sensor. - Ford Truck Enthusiasts Forums
Old 02-20-2005, 06:21 PM
444dieselrod's Avatar
444dieselrod 444dieselrod is offline
444dieselrod is gaining momentum as a positive member of FTE.444dieselrod is gaining momentum as a positive member of FTE.
I read about a map sensor mod on the "other" site . It involed a 1k and a 10K resistor in the map sensor. fooled the PCM into thinking it always had 20 psi of boost. well I tried it, no change, just a CEL. so I got ambitious today and tried to take readings from my map sensor, used an air compressor to simulate boost, at 0 psi and at 20 psi the resistances, and the voltage across all the teminals was the same. It NEVER changed, from 0 all the way up to 40 PSI, nothing happened, I never even got a CEL at 40 psi.
Anyone know how these things work, like what kind of signal does it send back to the PCM, and does it sound like mine is bad????
Diesel Rod
Old 02-20-2005, 07:15 PM
jadel jadel is offline
jadel is starting off with a positive reputation.
Iam not sure ,but the other day i thought i would try unhooking my hose on the map sensor that comes from the turbo and it was very slow to pick up speed and very low on power so maybe you could try this test and see if it works this way.
PID 3D Episode 3: Air's your problem Tugly 1999 - 2003 7.3L Power Stroke Diesel 0 12-25-2016 09:58 AM
EBP SENSOR reading 0 psi. ? A Rodder 6.0L Power Stroke Diesel 40 03-10-2016 03:50 PM
Low boost, no power lemonshindig 1994.5 - 1997 7.3L Power Stroke Diesel 2 05-24-2014 05:25 AM
Power Loss Problem Solved - BARO sensor was the culprit OldWoodsDiesel 1994.5 - 1997 7.3L Power Stroke Diesel 42 12-21-2013 12:02 PM
Map Sensor Question lethal5point7 1999 - 2003 7.3L Power Stroke Diesel 7 06-21-2006 09:14 PM
Tags
1999, 73, 73l, bad, deisel, diesel, f250, faulty, ford, liter, map, powerstroke, sensor, signs, symptoms
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
