Go Back   Ford Truck Enthusiasts Forums > Misc. > Appearance & Dress-Up
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Appearance & Dress-Up SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 02-20-2005, 03:42 PM
doberman doberman is offline
doberman is starting off with a positive reputation.
aluminum rims
Any suggestions on how to bring back the polished finish on my factory rims?
Have only used approved cleaners and a soft mitt.
2004 f350 4x4 TD
  #2 (permalink)
Old 02-20-2005, 11:12 PM
stephenw stephenw is offline
stephenw is starting off with a positive reputation.
Don't know if your rims have a clear coat or not? If so, then I have had good success with a coat of wax over a polishing compound. If not, then both Mothers Metal Polish and Blue Magic seem to do a nice job, either take a bit of elbow grease.
  #3 (permalink)
Old 02-21-2005, 12:52 PM
Sn0wMan Sn0wMan is offline
Sn0wMan is starting off with a positive reputation.
Mothers aluminum polish has worked best for me. More you rub the better it will look.
  #4 (permalink)
Old 11-24-2005, 11:09 AM
Dieselhound Dieselhound is offline
Dieselhound is starting off with a positive reputation.
There are two types of coatings on Aluminum rims these days. Clear powdercoat or Brite-dip anodizing. My lariat rims seem to be anodized and just washing them with car soap and fuzzy mit, plus drying them with a towel makes them look like new.
__________________
04' F-250 CC Lariat PSD. Prodigy BC, Tuff Skin spray-in bedliner, Husky floor liners, Beagle and Terrier hanging out windows. Engine built 6-25-04, tranny 6-30-04, truck 7-4-04. No problems.
  #5 (permalink)
Old 11-26-2005, 04:29 PM
johnsonswamp's Avatar
johnsonswamp johnsonswamp is offline
johnsonswamp is starting off with a positive reputation.
Quote:
That stuff works great, just don't breath any of the fumes..
__________________
  #6 (permalink)
Old 03-09-2006, 02:38 PM
Pkupman82 Pkupman82 is offline
Pkupman82 is gaining momentum as a positive member of FTE.
I have a set of factory 10 hole aluminum rims on my 84 F150. My concern is, I am planning on installing a new exhaust on this truck; I am wanting to run the tailpipe out the passenger side in front of the rear tire. I heard rumors doing this will harm the finish on aluminum wheels, is this true? Any feedback is appreciated!
__________________
1977 Ford F250 XLT Ranger 4wd/ 351m/ 4 spd
1984 Ford F150 4wd/ 300 six/ 4spd
1996 Ford F150 XLT 4wd/ 300 six/ ZF5
1984 Ford F250 XL 4wd/ 6.9 IDI/ C6
G.Fs. Trucks: 1977 Ford F150 4wd/ 351m/ C6 1990 Ford Ranger 4wd/ 4.0/ A4LD
  #7 (permalink)
Old 03-09-2006, 10:36 PM
72Lester's Avatar
72Lester 72Lester is offline
72Lester is starting off with a positive reputation.
Quote:
It will definitely "smoke" the color of the rim it is in front of due to heat, exhaust gases, etc leaving it with a brownish tint...but the degree of discolor depends on how close it is to the wheel and how hot your exhaust is. Some 1997 F-150s came factory with exhaust in front of the wheel and it permanently smoked the rims although the ones I saw were steel-painted not aluminum so I don't know how aluminum would hold up. Ford went away from that style because of the discoloration and it would also cause condensation to build up in the rear brake assembly and then freeze in cold climates...which I saw for myself on our work trucks many times while living in NoDak. I think if you went with dual exhaust (disperses the gases & heat so one wheel doesn't get it all) and rotated your wheels frequently it won't be as much of a problem.
__________________
99 F350 CC 4x 7.3 6spd - AIS/DP 6-flip/5"MR/CCV/ZooDad/SSHPX/ISSPRO 2-Gauge/MAP Line Regulator/WW/Powerslot Cryo
03 F250 CC 4x 6.0 AT King Ranch - stock
  #8 (permalink)
Old 03-11-2006, 09:22 PM
boxcar1974's Avatar
boxcar1974 boxcar1974 is offline
boxcar1974 is gaining momentum as a positive member of FTE. boxcar1974 is gaining momentum as a positive member of FTE.
2004 f350 4x4 TD
A good wash, clay bar, and wax should do the trick. I have the older lariet wheels and they still look good with 60K miles on them.
__________________
03' F-250, XLT Sport, V10, Banks Powerpack, SVT 18x8 wheels, and Toyo Open Country A/T 285-65-18E
09' F-350, XLT, V10, Regular Cab
Michael
  #9 (permalink)
Old 03-14-2006, 03:35 PM
Quote:
I don't want to run duals anymore I'm tired of busting hangers all the time. I was hoping I would be able to run my tailpipe before the rear tires, it would be cheaper and easier that way. But if I must run it behind the rear tires I'll do it, it has to be somewhat quiet... if it's too loud; I won't be able to run my truck in the dunes. Your input is greatly appreciated, any other suggestions? Thanx again!
Pkupman82
__________________
  #10 (permalink)
Old 03-16-2006, 03:38 PM
skrappy skrappy is offline
skrappy is starting off with a positive reputation.
find a good polishing compound and once theyre polished use corn starch on them to clean the black gunk out of the pits
  #11 (permalink)
Old 03-17-2006, 08:21 AM
TexasGuy001's Avatar
TexasGuy001 TexasGuy001 is offline
TexasGuy001 is gaining momentum as a positive member of FTE.
Purple Polish is by far the best and easiest. If they are factory wheels they probably don't need polish though.
__________________
1995 F-150 XLT 2WD 5.0 AODE (4R70W) 3.55 LS
1965 Mustang 302 T5
PICTURES AND INFO IN GALLERY
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
