1991 f150 towing capacity - Ford Truck Enthusiasts Forums
Old 02-19-2005, 05:21 PM
gfalin1959 gfalin1959 is offline
gfalin1959 is starting off with a positive reputation.
does anyone out there know the tow rating for a 1991 f150 4x4,4.9 liter with 355 axles?
Old 02-19-2005, 05:37 PM
79_250RangerLariat 79_250RangerLariat is offline
79_250RangerLariat is gaining momentum as a positive member of FTE.
auto/stick? do you happen to have the owners manual?
Old 02-19-2005, 08:49 PM
sorry dont have an owners manual and it is an auto
Old 02-20-2005, 02:10 AM
SoCalDesertRider SoCalDesertRider is offline
SoCalDesertRider is gaining momentum as a positive member of FTE.
About 11,000 lbs GCWR (gross combined weight rating), minus the weight of the truck (4,500-5,000 lbs), so probably around 6,000 lbs max trailer weight.
Old 02-20-2005, 07:12 AM
thanks guys i couldnt find this info anywhere
Old 02-20-2005, 10:07 PM
ford390gashog's Avatar
ford390gashog ford390gashog is online now
ford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to all
about 6,000 max with trailer
Old 02-21-2005, 09:54 AM
jroehl jroehl is offline
jroehl has a spectacular reputation.jroehl has a spectacular reputation.jroehl has a spectacular reputation.jroehl has a spectacular reputation.jroehl has a spectacular reputation.jroehl has a spectacular reputation.jroehl has a spectacular reputation.jroehl has a spectacular reputation.jroehl has a spectacular reputation.jroehl has a spectacular reputation.jroehl has a spectacular reputation.
From the '90 owner's manual, the GCWR for a 4.9/AT/3.55 combo is 10,000 lbs. I can't imagine it went up much from that for '91. Max frontal area for the trailer is 60s.f., too.
Jason
Old 02-21-2005, 10:55 PM
jroehl, turns out I was over by 1,000 lbs on the GCWR estimate. I thought the inline-6 was rated the same as the 351. Sorry guys.
Going by jroehl's info, the max trailer tow capacity would be about 5,000 lbs. My apologies for the error.
Old 05-12-2014, 11:10 PM
antiqbob antiqbob is offline
antiqbob is starting off with a positive reputation.
Ok I have a question.. How much would having a 302 engine change the towing capacity?
Anyone care to venture a guess??
I have a 26 foot Argosy (airstream) travel trailer coming in at 2600 lbs empty..
I made an 800 mile trip already bringing the trailer home and didnt encounter any major
issues other than the lack of trailer braking on wet roads.. I really tried to avoid pushing it at all..
My 91 F-150 is equipped with a class 3 hitch, and if it looks like the F-150 will not be overloaded than things like a trans cooler will be installed. The F150 has an AOD automatic trans. I did use it without going into od. With one exception on the way home for maybe 50 miles. I couldnt see any issues, but again did not push the trans. And any incline went back to Non overdrive.
Any thoughts?
Thanks
antiqbob
Old 05-23-2014, 02:17 PM
Thanks for the Reese info.. never tried that..
Thanks
Antiqbob
Old 05-23-2014, 02:23 PM
Nate
Sorry maybe I was just missing it but never did get a towing capacity for my truck.. A lot of accessories available but no specific information abut my truck.
antiqbob
Old 06-12-2014, 07:02 PM
Torklift Sheryl's Avatar
Torklift Sheryl Torklift Sheryl is offline
SPONSOR
Torklift Sheryl has a good reputation on FTE.Torklift Sheryl has a good reputation on FTE.
I've found that TrailerLife's towing guide is a great resource.
Torklift Sheryl
__________________
Torklift International Towing, Suspension, Tie Downs, Steps
Call me direct: 1-800-246-8132
Visit our Blog: http://www.torklift.com/blog
Old 06-12-2014, 07:25 PM
91 F-150 towing capacity
Sheryl,
My thanks, but again no reference to a 91 ... Maybe I should just sell it and buy something newer so I can find out the towing capacity...LOL
Thanks anyway.
Antiqbob
Axle options for a 1991 f250 danger fx4 ranger 1987 - 1996 F150 & Larger F-Series Trucks 8 04-30-2016 07:33 PM
1991 f150 4.9 l fuel rail curtisbutlerjr WTB - Parts & other 1 08-21-2014 09:44 PM
1991 F150 Parts cherrybomb37 Ford Truck Parts for Sale 1 08-11-2014 09:27 PM
Tow pkg wiring, fuses? Diagram? jeffbradbury7 1987 - 1996 F150 & Larger F-Series Trucks 4 08-14-2013 09:45 PM
EFI Wiring Diagram for 1991 5.8? Hodroddaddy Engine Swaps 2 08-11-2013 10:50 AM
Tags
1991, 1992, capacity, capicity, determine, f150, f250, ford, gas, guide, motor, ranger, straight, tow, towing
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
