Uh oh, rattle in oil pan
not fully sure, but is there any more info u can give us? is your truck running fine? Any oil presure drops when you come to an idle, or if you rev it in park? Unlikly, but the pickup tub from the LP oil pump could be lose and moving around. Other then that i'm not to sure. I do know that in order to pull the oil pan, u have to retrieve the whole motor. And trust me. i've done that to mine 3 times now.. Its NOT alot of fun... However if you do have to do that and have any questions feel freel to ask. (e-mail is easiest)
It's not unheard of for the occasional piston cooling jet to fall out and into the pan. They're just press-fit in. Their purpose is to spray oil on the underside of the piston to help keep it cool. It's a little u-shaped tube. You should definitely try to fish out whatever is in there, though usually people find these cooling jets as they slide out the drain hole while changing oil, so I'm not sure how you fish one out that's not cooperating like that.
When people have this happen under warranty, they make Ford fix it. But it's never been clear how critical it is if you're not pushing your truck to the limits, since those trucks clearly ran without them for numerous miles before the missing jet was discovered, and it just gets replaced without any concern for long term damage to the engine.
Duncan
Duncan
Are you sure that he's pulled the pan with out pulling the motor.... I just rebuilt my motor and i know exactly where the cooling jets are.. They aren't up far, but far enough.. And the oil pan is going to be a mother to get out if you can figure out a way with out pulling the motor... I mean ya, u could raise the motor, only after taking the turbo off and a few other things.. I know its not something you would want to do, but I don't think it would hurt to pull the motor, spin it around and get a chance to check out how that cylinder wall looks thats missing the oiler. It could be fine, and it could be wearing bad.. And as someone who just got to have the fun of paying for a rebuilt with everything getting redone I'll tell you that you would like to avoid that if at all possible.. just my 2 cents...
Are you sure that he's pulled the pan with out pulling the motor.... I just rebuilt my motor and i know exactly where the cooling jets are.. They aren't up far, but far enough.. And the oil pan is going to be a mother to get out if you can figure out a way with out pulling the motor... I mean ya, u could raise the motor, only after taking the turbo off and a few other things.. I know its not something you would want to do, but I don't think it wouldn't hurt to pull the motor, spin it around and get a chance to check out how that cylinder wall looks thats missing the oiler. It could be fine, and it could be wearing bad..
I just got to rebuild my motor work, which includes sleeving to cylinders, replacing somet pistons, a ring set, and all the other goodies... So of course its ur call, but if you want the longgevity out of the motor, you need to take every step possible to insure its not pointless wear.
Hope all goes well. Keep up updated
Thanks for the replies. We will pull the pan first, then make sure what it is that is loose.....then go from there. Nephew seems to think it is a cooling jet; if so they will fix it. If not they will fix it anyway. All done in the Ford shop according to Ford specs. Should add that nephew is a service manager for a large chain of Ford dealerships.
Try to use a magnet to lure the loose piece to the drain plug. You may be able to identify it even if you cant get it out it. Big difference between an oiler and a nut off a rod cap. You can go in through the drain plug with the magnet or you can try to pull it to the plug area by staying on the outside of the pan with the magnet. Naturally if it's not ferrous metal it won't respond to the magnet. I used to keep a small but powerful magnet stuck to the oilpan near the drain plug. Maybe this would help figure it out before you open it up.
