Go Back   Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
  #1 (permalink)
Old 02-18-2005, 09:08 PM
sikboater sikboater is offline
Garage is empty, add now
sikboater is starting off with a positive reputation.
Stuck oil filter
Any idea's on how to get a stuck oil filter off? I have just about broken a filter remover and bent a screw driver trying to get it off. I just bought the truck so who knows when the oil was changed last.
I am about ready to put a crow bar through it but don't want to destroy the filter. Plus it the truck is already drained, so I can't drive it anywere. !!
Also any tricks to getting the fuel filter off too? It seems to be put in very tight also.
Thanks in advance!
Tim
  #2 (permalink)
Old 02-18-2005, 09:21 PM
barebackjake's Avatar
barebackjake barebackjake is offline
barebackjake is starting off with a positive reputation.
ive got a pair of really really big channel locks that i used to use when it was on a little too tight.
i had one that got stuck on there soo good, got a 1" bolt and welded 2 spikes on it drove it in and used a socket and rachet to geter out.
__________________
97 F250HD 4x4 supercab 5sp 270k mi
4 link on air front and rear
2000 F350 CC 4x4 (wifes)
RIP CHRIS. 03/09/05
  #3 (permalink)
Old 02-18-2005, 10:18 PM
Freakazoid!'s Avatar
Freakazoid! Freakazoid! is offline
Freakazoid! is starting off with a positive reputation.
Got two tricks for you:
Normally I use a strap wrench, which is just a piece of square bar stock that a 3/8" ratchet fits into, and a cloth strap, similar to a tow strap (but smaller), and as I turn the wrench, the strap winds around the stock, eventually tightening up on the filter, and twisting it out.
The alternative (this works best for those that use a normal oil filter wrench), is to put a rubber glove (or latex or nitrile) over the filter and then put the filter wrench on the glove - it will give a pretty good bite on the filter. That's most useful when the filter is oily and greasy.
I also remember way back when my dad had a giant Pontiac diesel station wagon and the filter got crushed, he ended up cutting away the filter until only the part that seats against the adapter was left. Then he and our neighbor welded up this tool that had two bolts poking out that fit into the backside of the face of the filter (where the 6 or so holes for the oil to go out of the filter were) and twisted it out that way. That particular oil change was completed in only two days. I wish you better luck than that!
__________________
NEW 12/30/10: 2001 Excursion Limited: PSD, AT, 4x4, 6" lift
1997 F350 XLT: PSD, AT, Crew Cab, DRW
1995 Bronco XLT: 5.0L, ZF 5 Speed
1966 Galaxie 500: under construction!
  #4 (permalink)
Old 02-19-2005, 06:07 AM
BigRed350 BigRed350 is offline
BigRed350 is starting off with a positive reputation.
Thanks in advance!
Tim
Tim, the big Channel-Locks will do the trick, so will hammering a large screwdriver through it! As for the fuel filter, that same big screwdriver between the "vanes" on the cover will give you the extra leverage you need. You may have to remove the plastic box over the filter to gain some room though.
Good luck!
__________________
1997 F-350 XLT, LB, CC, 7.3PSD, Auto, 4.10, 4x4, 140,000 miles, 3.15xR75X16, PW, PDL, PB, PS, Tow Pack., Off-road Pack.
1971 Corvette Coupe, 454 LS-6 465hp.Muncie c/r 4sp. 85,000 miles, AC, PB
  #5 (permalink)
Old 02-19-2005, 03:58 PM
Thanks for the help.....
I finally got it off with a really big screw driver and a few holes in the filter.
Tim
  #6 (permalink)
Old 02-19-2005, 08:13 PM
mybigredford mybigredford is offline
mybigredford is starting off with a positive reputation.
good to hear you got it removed, but i use channel locks too, them things really grab good.
__________________
CLINT
2002 F350 XLT 7.3L PSD 4X4 Bellowed up pipes, HPX, CCV mod, foil delete mod, AIH Delete
  #7 (permalink)
Old 02-20-2005, 09:51 AM
bodabdan's Avatar
bodabdan bodabdan is offline
2003 Ford F-350
bodabdan has a good reputation on FTE.bodabdan has a good reputation on FTE.
In the future you may want to punch a hole in the bottom of the filter to allow it to drain the oil in the filter. It really cuts down on the mess. I use a strap wrench when needed. You can find them made with a strap made of chain, nylon, or rubber. They will fit a large variety of sizes, and they are useful for hundreds of other uses.
__________________
2003 F-350 for sale-http://www.ford-trucks.com/forums/12...l#post12446411
97 F-250 PSD, 2012 F-350
  #8 (permalink)
Old 02-20-2005, 11:53 AM
SpringerPop's Avatar
SpringerPop SpringerPop is offline
Too old to be too smart
2000 Ford F-350
SpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputation
There's a guy on eBay that is usually selling the proper-size (Lisle p/n#53250) filter wrench for PowerStroke-sized filters. Your local Napa may carry them, too. They are plenty heavy-duty, and have never failed me.
SpringerPop
__________________
-Marv- one of The Brotherhood
"Some of us pride ourselves on the money we've spent on our trucks, and some of us on what we have NOT"
2000 F350 Lariat 7.3,A/T,CC,LB,4X4,SRW, CCV, Sonnax/springs, Dahl, spin-on trans filter, spin-on hydraulic filter, coolant filter, 6637 & cover, bypass lube oil filter, HPX, Hutch n' harpoon.
Email SpringerPop SpringerPop's F-350
  #9 (permalink)
Old 02-22-2005, 02:24 PM
i also punch a hole in my filter like bodaban said but just make sure you get the filter a little loose before you punch the hole cause if you cant get it off then what do you do if you dont have another vehicle to drive for the time being? might be a problem since you now have a hole in your filter. just something to think about.
__________________
CLINT
Tags
73, corvette, f150, f250, filter, filters, ford, fuel, jammed, oil, powerstroke, stuck, tools, tricks, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
