1997 f250 7.3 fuel supply pump - Ford Truck Enthusiasts Forums
Old 02-18-2005, 07:16 PM
homer4111 homer4111 is offline
homer4111 is starting off with a positive reputation.
on my newer f350 there is a electric supply pump in the frame i have 2 tanks and cant find a supply pump. are they in the tanks? thanks
Old 02-18-2005, 07:20 PM
Frobozz Frobozz is offline
Frobozz is starting off with a positive reputation.
It's in the valley of the engine, down near the back (behind the fuel filter canister, and just starting to disappear under the turbo.) It's a 2-stage mechanical pump driven off the camshaft, not an electric pump like on the Superduties.
Duncan
Old 02-18-2005, 07:59 PM
do these go bad as i am having a supply problem at higher rpms? almost like it is starving for fuel?
Old 02-18-2005, 09:56 PM
ltfox's Avatar
ltfox ltfox is offline
ltfox is starting off with a positive reputation.
You can check the pressure at the fuel pressure regulater. It has a schrader valve that you can use to check it. should be about 40-50 lbs stock at idle. Another thing that may cause the same sysptoms is a weak high pressure oil pump. Just a thought. If you go to change the fuel pump, PM me. I got a great write-up on exactly how to get it done that I can e-mail to ya. good luck.
Old 02-18-2005, 11:44 PM
kawika's Avatar
kawika kawika is offline
kawika is gaining momentum as a positive member of FTE.
Hows your fuel filters? Have they been replaced?
Old 02-19-2005, 12:26 AM
Kwikkordead's Avatar
Kwikkordead Kwikkordead is offline
Kwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputation
Quote:
I have no personal experience on the mechanical fuel pumps on the PSD, but I have read that the fuel pumps fail and with the exact symtom you describe. I also have heard there is screen in the filter bowl that gets blocked up with crud. You need to remove the filter and clean out the screen with as many Q-tips as necessary to get the job done.
Old 02-20-2005, 09:35 PM
bogginf350's Avatar
bogginf350 bogginf350 is offline
bogginf350 is new and has a neutral reputation at this point.
I just picked up a 96 f350 stroker. Has 120k and would just weez out over 1/2 throttle and would not want to rev up to 3000rpms. I took the fuel filter out and drained the bowl. It had a good 1/8" inch of crud in the bottom. I removed the fpr and all the wiring and hoses and pulled the housing out and cleaned it. The little screen kwikkordead was talking about was all but completely plugged. Its like a little plastic piece that a screen is glued to in between the Fuel press reg and the fuel bowl. Needless to say I found a couple burnt wires and bad plug ends so I get to make a trip to the stealership tomorrow and get parts before I can try it out.
Old 02-21-2005, 07:53 AM
fast freddie fast freddie is offline
fast freddie is starting off with a positive reputation.
Itfox, I would really like a copy of the fuel pump procedure also if you don't mind. I have an oil leak where mine joins the engine. Will PM you. Thanks in advance..
Old 02-21-2005, 06:50 PM
ltfox's Avatar
Sent it to ya. Let me know if for some reason it did'nt get to you.
Old 02-21-2005, 06:55 PM
gameboynws's Avatar
gameboynws gameboynws is offline
gameboynws is starting off with a positive reputation.
Mine failed all at once. I was pulling a trailer to a horse show and truck started losing power and engine quit completely with in 2 mins from when it started losing power. Went out at about 130k.
Old 02-21-2005, 08:26 PM
BigBill33 BigBill33 is offline
BigBill33 is starting off with a positive reputation.
Smile 97 F250 Psd
I replaced my fuel pump last year after smelling fuel and seeing small leaks. While doing this, replace the fuel filter and as has been noted, clean out the fuel cannister, the fuel lines, and the mesh screen. Don't lose the o-rings!
However, be extra careful when removing the fuel pump. The pump has a piston on it for the pump that fits into the engine. While removing it be careful to watch it while removing it out of the valley or it might fall out and into the engine. I know from experience and have the remnants of it in the bottom of my oil pan. Replacing the hoses can be a chore too as there is not much space between the fuel pump and the bottom of the bowl.
Also, getting to the valley is fun, but while there, clean it out with brake cleaner or Simple Green. I am sure you might find some things dropped down there!
Have fun! You can do this job, but it will take some time.
Bill
Old 02-22-2005, 07:55 AM
IB Tim's Avatar
IB Tim IB Tim is online now
Site Administrator
IB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputation
...Welcome to Ford Truck Enthusiasts! If you have a minute check out the Guidelines, it will help you to navigate through and understand FTE.
Nice first post!
We are pleased you have chosen the best source for Fords!
Enjoy FTE
..See you on the boards.
Old 02-22-2005, 11:08 AM
wycowboy's Avatar
wycowboy wycowboy is offline
wycowboy is starting off with a positive reputation.
Hey ITFOX,
If its not to much trouble I would love a copy of that write up too!!, Im not quit sure how the email funtion works though.
I have a 97 and have a small fuel leak in the valley , It pools down by the lift pump, I think its coming fron there. dose that sound like a fuel/ lift pump problem?
Thanks you guys, J
Old 02-22-2005, 06:35 PM
ltfox's Avatar
Quote:
Originally Posted by wycowboy
Hey ITFOX,
Thanks you guys, J
Click on my name and choose to PM me. Then as this is a word document if ya will give me your e-mail I can send it as a attachment to you. Layne
Old 03-12-2005, 10:59 PM
bill farrell bill farrell is offline
bill farrell is starting off with a positive reputation.
Hey BiGBill33, Am I to understand your pump plunger is still in the bottom of your oil pan. I did the same thing, was changing out the pump and the plunger fell thru past the camshaft and I assume into the oil pan? I don't really want to pull the engine to get the pan off if ya know what I mean.
Thank's Bill Farrell
Spectra fuel tank and pump nissen4 1987 - 1996 F150 & Larger F-Series Trucks 14 07-07-2016 09:44 PM
1989 F250 dual fuel tank issue donskrin 1987 - 1996 F150 & Larger F-Series Trucks 11 11-30-2015 09:27 PM
Fuel: Runs for a few minutes then dies 904man Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 16 09-23-2015 08:33 AM
Bronco fuel tank in f250 shryock10 1987 - 1996 F150 & Larger F-Series Trucks 6 08-13-2015 11:41 AM
86 f350 7.5 smog pump rebuild armashby 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 2 07-24-2015 11:54 AM
Tags
1997, 73, 73l, f350, fell, feul, fuel, lost, mechanical, plunger, powerstroke, psd, pump, supply, turbo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
