I just received my Orings and gaskets from RiffRaff. In the kit there are 2 sets of Orings, one set black and one set green. When I removed my oil cooler, there are only one set of Orings on it, black. Am I missing something, or is my oil cooler missing something (extra set of Orings)?
Well, had a buddy use his press to press the ends back on. I'm standing there watching and before he even puts much pressure, the filter end splits in half.
Things just keep getting better.
Key is to make sure those ends are completely straight going onto the cooler. I found that a rubber mallet and a close eye helps with making sure that they are level.
I thinking I've got an extra filter end too, if you need one.
Just so I don't have to order another end, is it easier to do one end at a time as opposed to trying to do both at the same time? I'm thinking this is where I went wrong and created more work for myself and more expense.
Thanks for the link Andrew. I have to say that Engine looks sweet. Wish I had the time and money to pull mine and go through all that. Just not in the cards right now.
