You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
my bypass valve cracked. the dealer say you have to buy the complete supercharger to get the vacuum valve. this is nuts anyone have a solution thanks keith
That is one of the craziest things I've heard in all the years I've been surfing these L boards. How the hell did you crack that thing? If Ford doesn't show that piece as a seperate part # then it sounds like you are screwed cause finding a used one is pretty much impossible. These things get stripped almost before they hit the ground in a bone yard. Anything engine related on a wrecked L is normally sold with the engine.
the only thing that broke off was the nipple. i can fix it . and it needs to be there for when ya snap the throttle plates closed to relieve pressure and prevent damage to rotors. but this is like a choke pulloff on a carb imagine having to buy a new carb because the pull off diaphragm wasnt sold seperatly. good job ford.........
A draw through blower doesn't need the valve to prevent boost from backing up and hurting the rotors. It's there as a passive traction control system and to reduce blower load under part throttle.
__________________
1990 F-150XLT Lariat Stillon the original engine with no squeaks or rattles at over 300k miles
4.9/M5OD/3.08
16.89@77.09
145 rwhp, 272 rwtq
2001 Lightning #127
13.18@104, no chip, no pulley, no nitrous
Confuscious say "Man who have no use for jackstand have promising career as jackstand".
i have a 671 on a bbc and it never hurt the rotors with no bypass. but i was under impression that bypass allows virtually no parasitic loss under no load conditions. i found a valve in mi for 45.00 so i am getting it anyway thanks
