dodge 6spd vs ford 6spd
Originally Posted by Tim Lamkin
Your asking a question about speculation, UNLESS the same person owned two trucks and pulled the same grade with the same trailer....how is anyone going to answer this....with out it being speculation/Opinion
Curious I am!
Curious I am!
This could be more difficult to find that person than you think
When it comes to manual transmissions, I like Dodge's approach more than Ford's.
There are many differing opinions based on differing aspects of both transmissions.
When discussing Dodge's manual 6 speed vs. Ford's manual 6 speed, it actually comes down to two transmissions vs one, since Ford has been using the same transmission for quite a while now and Dodge has just changed over to a new one.
My limited experience with the ZF goes back a few years. I noted it was quite notchy then, but that was still nothing that I could'int live with. I expect some notchiness from a heavy duty transmission. The ZF's ratios are far superior to the wide ratio NV4500 5 speed that I had in my 96 Ram 2500. For the better ratios, and extra strength, I could live with the ZF's finickyness over the smoother NV4500. The ZF has'int got a very good reputation behind the 6.0 diesel, but this in no way should be attributed to the transmission - it seems the 6.0 was made to suit an automatic more than any manual transmission.
The NV5600 I know only from test drives. It is smoother and closer shifting than the ZF , but still somewhat notchy IMO. The NV5600 uses a cast iron case which is stronger than the aluminum that the ZF utilises of course, but how this added strength is of real benefit to the user I can't say.
The G56 six speed I also know from a test drive - you won't believe how smooth this transmission is unless you drive it for yourself. I can tell if someone online has actually test driven one - they say the very same thing. This new transmission comes with a dual mass flywheel which apparentely is not nearly as bomb friendly as the solid flywheel the NV5600 utilises. The transmission itself is geared much lower than the NV5600 it replaces and is currently only available with a 3.73 rear axle ratio as a result.
With 3.73's however, it recieves the same tow rating Dodge has bestowed on the NV5600 and 48RE with 4.10 rear axles.
So here's my view;
ZF Advantages
1.) Aluminum case dissipates heat more efficiently than cast iron does.
2.) Light weight yet high strength yields higher payload
3.) Has been in use for quite some time - we know it will hold up to everyday work.
4.) Reverse and low are inline with each other for easier trailer manuvering. (MOO)
5.) Has lower gearing in first than the NV5600.
6.) Integrated cooling system like an auto transmission.
7.) Best overdrive ratio for unloaded economy
NV5600 advantages;
1.) Cast iron case can withstand higher temperatures before rupturing.
2.) Uses heavy grade gear oil and does not require a cooling system of any kind.
3.) Has withstood severe bombing and extreme uses very well.
4.) Has a lower reverse gear than the ZF.
5.) First and second are inline with each other for easier shifts during loaded acceleration. (MOO)
6.) Closer and smoother shifting than ZF's I remember.
7.) Better overdrive ratio than G56 for unloaded economy
G56 advantages;
1.) Aluminum case means lighter weight and increased payload.
2.) Easily the smoothest shifting transmission of the three.
3.) Though a newcomer it has seen use primarily in medium duty Frieghtliner and Mercedes applications - stock reliability should not be an issue.
4.) Geared much lower than the other two transmissions in both 1st and reverse.
5.) Better overdrive ratio for towing economy
6.)1st and 2nd are in the same gate for easier shifting during loaded acceleration. MOO
MOO = Matter Of Opinion
As you can see all have advantages - it's a matter of looking at the glass half empty of half full. Personally, with the demise of the NV5600, I conceide the ZF as the most reliable manual transmission in current production as of right now. I do believe that this G56 is a winner though and will prove itself - Dodge has always had good manual transmissions with the exception of one.
I prefer the G56 for its smooth shifting characteristics, lower granny and reverse gears, and the shift pattern - but that's me - I certainly do not feel the ZF is in any way a bad transmission.
So here's my view;
ZF Advantages
NV5600 advantages;
G56 advantages;
