Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 SVT Ford F150 Lightning, Roush, Saleen and other performance F150's
1st gen spring rates
Old 02-15-2005, 07:55 PM
fastback69's Avatar
fastback69
fastback69 is offline
What are the spring rates for the 1st gen coils and leafs? I installed 1st gen coils and leafs on my truck ('94 swb, 4.9l, E4OD) along with Bilsteins (ak1289/1290). The rear is firmly planted but the front is a little bouncy. I also replace all the bushings with urethane and added front and rear swaybars. I'm thinking I need the shocks revalved or de-gassed to get both ends acting the same. My engine is only a little lighter than a 351W. 20 lbs lighter according to most weight lists. Thanks.
I searched but didn't find any specs.
Old 02-16-2005, 09:22 AM
Blurry94's Avatar
Blurry94
Blurry94 is offline
They're supposed to be the same (rating) as a standard F-150. The shocks are more performance oriented, and they have a bigger sway bar as compared to a regular 2wd f-150. Bilstein makes a shock for the GEN 1 L's that is much like the ones used on the GEN 2 L's. The ride overall ride is supposed to be like a stock L, but some said that they seem to be just a bit firmer than stock.
redwood
1997-2006 Expedition & Navigator
09-22-2013 08:03 PM
i eat hybrids
1999 to 2016 Super Duty
12-25-2011 10:17 PM
strokin'_tatsch
06-23-2010 07:29 AM
TexasGuy001
06-03-2009 08:49 AM
smitty302
01-31-2007 04:52 PM
Quick Reply: 1st gen spring rates
